TheMusketeer
- May 10, 2012
I'm debating between the two processors. I will mostly be doing video editing and cad and other things but no gaming. Which processor would be better for these tasks.
Thanks
Thanks
the 2600 can overclock with 103BCLK and +42Turbo boost.. that will net a 4.0GHZ under heavy loads.. up to 4.3GHZ in single threaded apps.. so.. nothing bad at all..
It can OC a whole lot better than that. Leave bclk alone and simply adjust the multi to 45 and get 4.5GHz in single multithreaded apps. You can go higher, I just used 4.5 as a decent baseline.
