zeusapollon
- Jun 6, 2013
zeusapollon n00bie, 3 Months
Status: zeusapollon is online now
Repasted the TIM again, took my time, and now the temps are back at "normal" again.
You're right, it might be that OCCT with linpack and AVX that did make the TIM uneven or something like that. AT least it was when I started running that stresstest my problems occured.
So guess it isn't dead after all! (still).
Started rising only the multiplier to 40, RAM at 1333 mhz at 1.5v and everything else on auto.
Theese are the voltages showing at auto:
vcore 0.912v
VIN/VRIN 1.864
VID 1.201
vRing 1.229
Testing before it needed 1.32 vcore to get 4.4 mhz stable with ram at 1866 mhz. 2133 XMP BSOD'ed.
Even at 1866 I experience some "hangs/freezing" for a couple of seconds if my computer stands on for a day or so. Wonder if it is something I can adjust on the ram voltages to adjust this?
Have tried VCCSA up to offset + 0.3, but kept DRAM at 1.65 at all time I think (Which might be high for 1866?). Have Kingston HyperX 16 GB 2400 mhz ram modules. 2133 mhz gives me BSOD (often 124), and 2400 mhz have several times failed loading even at stock cpu vcore with post message: fail, check RAM module A. (Or ram module B). Have to load default settings in BIOS again to get them to work again. Have switched both modules, and it isn't a one of them that gives the error every time. Ram module 1 can give the error in slot A2 or B2, as can ram module 2. So guess it's not the ram modules causing this?
As for deliding, read about great results doing this with the hammer method, and it gave me 18-20 degrees lower temps with CLU between the die and IHS. So worked great for me.
What vcore do you run at to get temps of 70-72?
vcore 0.912v
VIN/VRIN 1.864
VID 1.201
vRing 1.229
