Intel Gene-Z tries to start and dies
Discussion in 'Motherboards' started by lightsout, Oct 11, 2018.
  1. lightsout
    lightsout Gawd
    632
    Mar 15, 2014
    This board died on me a while back, I didn't put much effort into troubleshooting and it was out of warranty. Pulled it out today and wanted to give a shot at getting it going. CPU pins all look good to me. When I try to power it up, the PSU fan kicks on, the error code numbers start going, but it quickly dies and then tries again. It just goes in an endless loop like this. I am linking a short video, anyone think there is any hope for it?
    https://photos.app.goo.gl/YbWQLDyE7hRzTBE36
  2. lightsout
    lightsout Gawd
    632
    Mar 15, 2014
    Did some further testing, got into the bios and was actually able to start installing windows on a disk, but if you reboot or anything the issues start all over. I think I am going to call it dead. I'm sure Asus would charge an arm and a leg to fix it.
  3. Denpepe
    Denpepe Gawd
    875
    Oct 26, 2015
    You could try a Cmos reset if you did not try already, also check for an updated bios, you never know.
  4. pendragon1
    pendragon1 [H]ardForum Junkie
    10,733
    Oct 7, 2000
    replace the battery, see if that helps. ive seen dying ones cause all sorts of issues.
  5. lightsout
    lightsout Gawd
    632
    Mar 15, 2014
    Yeah done that a bunch.
    Worth a shot I suppose.
    pendragon1 likes this.
  6. Arcygenical
    Arcygenical Will Watercool for Crack
    24,647
    Jun 10, 2005
    I'm having the same issue with the same board. Actually.
    I can SOMETIMES get into the BIOS with a few proper resets.
    The code often hangs at d0.
    I can get windows to install.
    My main system is down for an RMA. Board's been in storage for 2 years.
  7. lightsout
    lightsout Gawd
    632
    Mar 15, 2014
    Interesting, yeah mine has been in a box for a long time, started acting weird and I just replaced it with a Z77 and moved on.
    Sometimes mine will hang at a code too, different one, sometimes it will die before it stops on a code, clearing cmos, moving ram around seems to do something, sometimes, but its way to fussy to try and build something
    with, would be too much of a nightmare. It was a sweet board in its time.
