secure.boy
- Oct 22, 2007
only 4 FBDIMM slotsI am dissapointed in the skulltrail system for the reason that it only supports dual sli, not tri or quad... and the price point is pretty staggering. Lack of adequate memory slots are also dissapointing, and that it has to be FBDIMM (not that FBDIMM is bad, but adds to the cost)
You are incorrect. The D5400XS does indeed support Quad-SLI. Quad-SLI is defined as two GPUs on one card. Two of those equal Quad-SLI which the D5400XS indeed supports. 3-Way SLI is the only SLI configuration not supported. NVIDIA themselves do not support 4-Way SLI so that hardly is a ding against Skulltrail. As for the price point, I agree. As for the memory configuration I can't. I don't like FB-DIMMs either, but I think 4 DIMM slots is good enough. The board supports up to 16GB of memory according to Intel. That is enough for workstation use and certainly enough for gaming.
BTW there is no QX9xxx series of processors that are compatible with the D5400XS. There is only the QX9775 at present in socket LGA771. All other QX9xxx processors are LGA775.
I was not assuming the GX2's when picturing quad sli. The least they could have done was tri sli... that would have sold it for me.
Perhaps in a future version of the board? Admittedly, it is a bit of a disappointment, but Quad-SLI should be more than sufficient for almost everyone.
