- Aug 20, 2006
Here’s Intel showing off their “crazy fast” memory, although the author of this article thinks the demonstration is suspect in some ways.
It is great to see XPoint / Optane technology being demonstrated again, but as far as demos go, this was not the best / fairest example that Intel could have put together. First of all, the 'NAND SSD' they are using is a Thunderbolt 3 connected external, which was clearly bottlenecked badly somewhere else in the chain (when was the last time you saw a 6 Gbit SATA SSD limited to only 283 MB/s?). Also, using SATA for the NAND example while using PCIe x4 NVMe for the Optane example seems a bit extreme to me.
