OverclockingGuru
- Apr 20, 2006
COD2 stayed pretty much the same
Obvlivion got a huge performance jump
OverclockingGuru said:no idea, but being that it's dual core optimized maybe the shared cache makes a difference?
tdx said:Don't mean to hijack this thread or anything, but, seeing how Conroe pretty much puts Opterons to shame, what do you guys think would happen in a similar battle between Woodcrests and Conroes?
I know neither have been released, but there has been preliminary tests of both. I'm asking cause I'm hesitating if my next purchase will be a Conroe rig or a Woodcrest one (and yes, I know the latter costs more, but if it's really more powerful than the Conore, I'll go for it).
Peace, TDX
MC FLMJIG said:WOW. That is a sweet Opty OC! Impressive that a tiny Connie OC and it's whipping it's toosh!!!
However once Connie comes out the Dual AMD's will dop down in price significiantly...
The E63 + 64 are dual aren't they??? If they are they will be roughly the same price point... that would be interesting to see... how the lower end Connies fare vs the x2 3800 and teh opty 165.
Great job on the testing!!!
InorganicMatter said:I wanted an E6600 for the extra multiplier in overclocking, but if they overclock THAT well I might be getting an E6200 or E6400. What would the difference be as far as the cache goes (2MB versus 4MB). I am amazed that this processor beat AMD's flagship price/performance part, at the same price, at a much less overclock.
Hmmm, good to know that about the lower-end ones. I bet the high clockers get made into 6600/6700s, and the low clockers get half their cache disabled and go into the 6200/6300 bin.tvdang7 said:Well it seems that the lower end conroes have trouble getting such high speeds.
Not a problem for me, the motherboard and PSU are the only two components I go all-out on. If a motherboard costs less than $150, chances are it won't end up in my box.tvdang7 said:Plus u need a very high end motehrboard
tvdang7 said:http://www.xbitlabs.com/web/display/20060606172841.html
well it seems that the lower end conroes have trouble getting such high speeds. plus u need a very high end motehrboard
The experiment showed that even if the second core was disabled completely and the Vcore was set to its maximum, Core 2 Duo E6300 processor doesnt allow to increase the system bus frequency beyond 477MHz. with the maximum clock frequency multiplier of 7x, it can only clock to 3.33GHz. It is not a bad result, but the mainboard should features really good overclocking-friendly options to achieve this. Most mainboards may face serious difficulties during this overclocking attempt, especially if the implemented Conroe support didnt imply wide frequency range for the system bus.
FUGGER stopped at 3.22GHz frequency achieved with a serial Freon cooling system. With the processor Vcore at its nominal value, the CPU clocked to 2.33GHz.
then it makes more sense for you to spend more money on a model from the middle of the product line-up, instead of getting the slowest one. In fact, P965 based mainboards may save you some trouble, but they will not be cheap, also. So, efficient Conroe overclocking will require some tangible financial investments.
Ilya Gavrichenkov XBits said:AMD has been offering Opteron processors for Socket 939 systems for quite a while now. Despite their server orientation they can suit quite well for desktop systems too. For example, our experiments showed that Opteron 165 is a really great choice for hardware enthusiasts. Read more!
WaterIsTasty said:nice, i'm glad i decided to hold out with my 2500+ mobile
brucedeluxe169 said:You are a god among men.. I loved my 2500 mobile @ 2.6ghz with a 6800gt....
until I destroyed it
Megalomaniac said:ditto here, still running my trusty 2500 xp-m clocked at 2500 with a 6800.. (upgraded from 1800 XP)
skipping a whole generation or two of cpus sure makes you appreciate the new stuff more
july and august are upgrade months
now to just pre order that E6600 and a good mobo and to OC it up the wazzu
thrawn86 said:read it again
"3.22GHz frequency achieved with a serial Freon cooling system"
I don't have a serial-whatever cooling system. and the 2mb chips will obviously be less in terms of performance
