I'm trying to boot diagnostic CDs, but every time I set the boot ordr to optical drive first, hard drive second , this fucking Intel Boot Agent flops up first and starts doing something which loops indefinitely. I cant see a way to override it in the mobo BIOS (I've set the optical drive as the first boot device for Christ's sake), and there's sweet FA to see in the NIC's own BIOS. Looks like you can disable it altogether via a DOS F/W flash, but I don't want to have to do that. I just want to boot a CD now and then. What can I do?
Well it's a network card causing the problem.
Thanks, the F12 menu slipped my mind. Problem solved.
You can turn it off in the settings of the Intel NIC in the > control panel > network and sharing > change adapter settings. Go to the local area network, properties, advance. Inside one of the tabs/settings, there is a way to turn off Intel Boot Agent.
He can't even get to that point, and I don't think it's bothering him inside the OS, it's booting to the OS which he can't do because of it.
Good call, but he needs to disable it before loading the OS, not after.
He didn't say he couldn't get into Windows.
