Yes on the noise and blocking....the actual gameplay footage does not have that or any stutter at all.all that blocking and noise from youtube? assuming so. those corner/replay shots are pretty damn convincing.
I will take this level of performance any day of the week for $349 over an 8 or 12 GB card with a narrow cut-down bus.
Every title I've run to date is smooth.
It may not have the peak fps as the RTX3060Ti or the RX6600 but I'll take the 'fluid' running all day and twice on Sunday over those two.
I have not had a single in game crash either with that A770...not one.
Is the card 100% perfect? No
I still have to manually install drivers but that also gives me the option over what I want to install.
I don't have any annoyance messages because I simply do not install the ARC Control Center.
All of the racing titles I run are older... AC (2013), Rfactor2 (2013), RaceRoom (2013), ACC (2018), RBR (2004).How many games have you played? Any particularly older games?
DP to HDMI can be trial and error in getting a working brand. Do those same DP to HDMI cables work on a different GPU, with the same display?I've already started a return. Getting flashing screen when I have it connected to the LG 4K TV in our bedroom which is where the system is located. Tried a HDMI to DP cable, no signal at all from the DP ports on the A770. Read something yesterday about another possible price drop on the ARC cards, I can see why.
sam
Another thing to note, is that some of those cables only work 'one way'. So, if you have it backwards, it won't ever work.
I don't do regular gaming....just racing simulations.Can we see footage of something other than racing games......
These cards are great not everyone needs/or can afford a $1200 GPU, Intel is making progress.Underwhelming but this is great for the market and consumers. We need more competition.
I would like to see more single slot GPUs honestly. I vaguely recall being irritated when GPUs started taking up multiple slots. Accept it as needed due to heat/noise, but still.The A60 is interesting as it's a single slot card (shocker). And might actually sit between a 380 and 750 somewhere. Just think it's interesting due to single slot.
Intel's initial impression wasn't great, but glad they kept hammering at it... while a RX 7600 is a better performer and value (talking about brand spanking new stuff), Intel has improved the most over time. Looking forward to Battlemage and beyond.
Also looking for better Linux support.
Just picked one of these up, a used Acer which was cheap. planning to pair it with a 5700X which I also got cheap with a B550 Tomahawk.
Quite excited to see how it performs, my daily driver is a 9 year old Z87 based system with a more recent 1660S, and while I fully expect this to eventually usurp it, I'll keep the old one running while Intel continues to update the drivers.
Great to see a third player enter the GPU scene, a well needed wake up call for AMD in particular.
I will do, hoping to put the build together next weekend, assuming all goes well I'll post some benchmarks.Post your experience after you spend enough time with the Intel GPU to give an assessment![]()
A750 vs RTX 4060 vs RX 7600.
For $100 cheaper, the A750 is on average 19% slower than the 4060 at 1080p. (Depending on the game)
The little A750 has come pretty far since it dropped almost a year ago.
View: https://www.youtube.com/watch?v=dVX6odo-bJ8
Not sure which should or should not be in the same ballpark, it is a $289 launch price GPU with a giant 406mm2 die and 256 bit memory bus compared to supposed to be similarly priced gpu (one with a 159mm die-128 bit bus, the other a 204mm on the same node than the 750 also 128bit bus)Shouldn't even be in the same ballpark and yet....
DL it and see if it works, and report back to us.Does anyone know if MSI afterburner works with Arc? I'd really like to take some screenshots with on screen FPS, temps and utilization data.
