Tyler-Durden
- Nov 18, 2012
Fantastic! Thanks for the update.Incredible build quality and sounds amazing.
Uh, not in my experience. Different amplifiers can sound very different indeed. I assure you, I didn't buy my Conrad-Johnson amp for its looks, nor my previous McIntosh amp that the CJ replaced.
I used to believe what you just wrote, until l heard for myself.
Onkyo has a few things you might want to look at
Also, on another note, completely ignore SnoFlo's assertion that different amps color the sound under normal operation. He can go win the RC Amp challenge and then get back to us on that. Or he can show us evidence of a double-blind ABX test that has proven his point (I am aware of several that failed to do so, though - some of them even including tube amps alongside solid-state). Until then, he's uninformed. Amps add almost no distortion to the signal - not even 1% as much as your speakers. It's insignificant. In any case, you shouldn't spend a lot of money on amplification (unless you'll actually use more power or the higher-end product has more features that you'll use) until you've bought your dream speakers. Or do room treatments.
Can't tell if serious.
My, my: such apoplexy. Calm yourself; it's just a stereo.
He's 100% correct.
And I say bs. If all well designed amps are the same, then there is no need for variety and there would be no need for some of the worlds best circuit/amplifier designers such as Nelson Pass, Bob Carver, John Curl, John Linsley Hood, Douglas Self and the list goes on and on putting effort into new designs circulating around different transistors, semiconductors and valves used in amplifiers of various designs be it monoblocks, power, integrated, hybrid class a or valves (SET, PP, OTL, SRPP) and etc.
I would agree that in general, most amps will sound similar unless driven to clipping. However it's very easy to drive many amps to clipping if you are using some hard to drive speakers. Two years ago at an AVS getogether a Salk Soundscape 10 drive a 300W/CH 80lb power amplifier to clipping in a living room, at a mere 50W/ch draw from the wall due to impedance dropping below 2ohms...
Now, on cue, someone will chime in that breaking-in audio components is rubbish. It probably is, but at least you have an excuse to use when housemates want to know why you're playing back test tones, 1812 cannons, and Tyrannosaurus rex roars at 120dB.
Also, on another note, completely ignore SnoFlo's assertion that different amps color the sound under normal operation. He can go win the RC Amp challenge (yes I've heard that this has not actually been available for years, but I still like to reference it - people would have won it if they could) and then get back to us on that. Or he can show us evidence of a double-blind ABX test that has proven his point (I am aware of several that failed to do so, though - some of them even including tube amps alongside solid-state). Until then, he's uninformed. Amps add almost no distortion to the signal - not even 1% as much as your speakers. It's insignificant. In any case, you shouldn't spend a lot of money on amplification (unless you'll actually use more power or the higher-end product has more features that you'll use) until you've bought your dream speakers. Or do room treatments.
