Installing w10pro when bios has w8home license
Discussion in 'Operating Systems' started by zorobabel, Jun 16, 2017.
  1. zorobabel
    zorobabel Limp Gawd
    172
    Aug 25, 2008
    I'm having trouble fresh installing w10 pro v1703 on a lenovo PC with a w8home key embedded in the bios.
    I never get asked if I want to install the home or pro version, and it just installs the home.
    Tips please?
  2. bigdogchris
    bigdogchris Wii was a Novelty
    16,514
    Feb 19, 2008
    You have two choices. 1) Install 8 again, verify it's activated, then upgrade directly to 10 to enable the digital license. 2) Clean install with a product key.
    In your case it looks like your only choice is option 1. Once done, you can clean install and skip the product key and it will reactivate.
  3. zorobabel
    zorobabel Limp Gawd
    172
    Aug 25, 2008
    What I ended up doing is change win key to:
    Windows 10 Pro Generic Key : VK7JG-NPHTM-C97JM-9MPGT-3V66T
    A couple of restarts later it became a Pro.
    This is a bad decision taken by M$ for the v1703 ISO, one more annoying thing about W10.
  4. auntjemima
    auntjemima [H]ard|Gawd
    2,015
    Mar 1, 2014
    This hard nothing to do with Windows at all. They don't decide that a product key is linked to your BIOS (I still don't think this was the case, however).
  5. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    5,584
    Feb 7, 2003
    How is this changed or specific to 1703? Thought this has been expected behavior since they started baking the keys into the boards on those royalty OEM boards back to the Windows 8 days.
  6. zorobabel
    zorobabel Limp Gawd
    172
    Aug 25, 2008
    Well, I tried W10 v10240 just for kicks, and it does give you the option to install home or pro. My issue is that v1703 does not give the option on this particular computer and just installs whatever cause it knows best.
  7. Lunar
    Lunar [H]Lite
    100
    Jul 26, 2007
    This is one of the many reasons why I hate that device manufacturers started embedding the product keys into the UEFI. I understand why they were motivated to do it, but it has been almost nothing but an exercise in frustration for me personally. What's really bad is when you're trying to reinstall Windows for a client, and you can't because the embedded product key got corrupted somehow. That's really fun....
    BulletDust likes this.
  8. BulletDust
    BulletDust 2[H]4U
    3,947
    Feb 17, 2016
    Been there, dealt with that! ;)
  9. B00nie
    B00nie [H]ardness Supreme
    5,396
    Nov 1, 2012
    I don't envy you guys if you have to install windows for work :wtf:
  10. YeuEmMaiMai
    YeuEmMaiMai [H]ardForum Junkie
    13,855
    Jun 11, 2004
    clean install windows 10 and then change your product key to a pro one..
    done deal
  11. pendragon1
    pendragon1 [H]ardness Supreme
    5,008
    Oct 7, 2000
    your key is for home so you get home. no free upgrades to pro.
