I recently purchased a Dell poweredge to replace my current file server. After finding out there is no NT support for the onboard SATA RAID controller I purchased a NT compatible PCI controller. A Highpoint Rocket RAID 1520. I had no trouble getting the card physically installed and using it to setup my RAID 1. But when I try to install windows NT 4 I run into problems. When setup first starts I press F6 to install new controller drivers. NT reads the provided driver disk and lets me select between NT, 2000, and XP drivers. When I choose NT the installation goes to the previous screen with a list of drivers that will be installed. I can see the Rocket RAID at the bottom of this list. So I continue installing... soon I am confronted with a screen that says the only mass storage device that was detected is my DVD drive. I press S to specify an additional device. I am presented with the same driver selection menu I saw earlier. When I pick the NT driver the installer jumps quickly to a screen reporting the device im trying to load is not installed on my computer. I have tried new drivers and modifying the txtsetup but nothing seems to work. I have also tried a single disk non-RAID setup. Any idea whats going on?
I should also mention this is the second PCI controller Im attempting to install. The first one was a link depot sata RAID controller. When I tried to load the driver for that card the windows installer would crash.
