Every time I try to open a web page I get a message
"The feature you are trying to use is on a network resource that is unavailable."
"Click OK to try again, or enter an alternate path to a folder containing the installation package..."
I used the "Reset" feature of IE7, that didn't help.
How can I tell how/why this installer is being run each time I run IE? I couldn't find anything using Hijack This.
