firas
- Oct 29, 2006
When is that article from? SP1 is in release candidate form available from technet and is at build 17158 right now... I highly recommend installing it. It fixes a lot of little nagging bugs like Vista being unable to count worth a damn in file transfers, speeds those up as well, and introduces EFI support and boots quite a bit faster as well.
In order to upgrade to another version of SP1 you just uninstall it from add/remove, and then download and install the new one.
SP1 RC Refresh, the latest release, went without a hitch and seems to have speeded up everything for me. Vista seems pretty SNAPPY now. Benches show increase as does Crysis bench (both DX9 and 10) Very pleased and unexpected. ALso solved several other problems for me.
Booker, I believe it's RC, so it's not going to be run through the 'Windows Updater'
Here is the link you'll need:
http://www.microsoft.com/downloads/...82d-9524-de850c4dd91c&displaylang=en#Overview
