Innodisk Launches 4K M.2 Graphics Card
Discussion in 'HardForum Tech News' started by AlphaAtlas, Dec 5, 2018.
  1. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    10,472
    Jun 13, 2003
    Media center PCs are essentially dead. They've been replaced with Android boxes (Nvidia Shield) and Apple TV.
    You'd be extremely lucky to get something as well developed and supported as Intel's HD/UHD graphics in there.
    defaultluser likes this.
  2. zkostik
    zkostik Gawd
    931
    Sep 17, 2009
    Yeah, I guess it's hard to disagree. Given the small footprint of an M.2 card that likely is the biggest limiting factor and not bandwidth. Though I still think x4 is too narrow for a modern GPU. I'm yet to see an M.2 slot that has more than 4 lanes, not to say it isn't possible just nobody seems to design that way. Doubt much will change as potential for a video card in that slot is limited at best. Maybe via some kind of header cable a custom card can be connected elsewhere in the case. This GPU either has no VRAM or 245MB GDDR3 so it is heavily depending on its link speed. Still an interesting concept but I really just don't see this being feasible, not even for digital signage as Intel iGPU is most likely more than sufficient without extra cost and cooling requirement.
  3. zkostik
    zkostik Gawd
    931
    Sep 17, 2009
    Well speak for yourself regarding media PC. It has always been a relative niche market but overall suckage of Android for that purpose hasn't changed for anyone wanting more advanced features/software. Android and Apple TV are for typical user who only consume streaming content really.
  4. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    28,044
    Oct 29, 2000
    While I agree, I think one application could be to add newer hardware video decode capability to an existing system.
    If you are relying on Intel IGP at this point, you have to replace the CPU to upgrade to new video decode capability, and if you replace the CPU, due to them changing sockets every goddamned generation, you have to replace the motherboard. There is a real chance you may have to replace the RAM too.
    Much easier/cheaper to slip in a super low end M.2 GPU.
    But as you say, Media Center PC's are mostly dead unfortunately. I mean, I still use them, but I know I am in the significant minority.
    IdiotInCharge likes this.
  5. defaultluser
    defaultluser [H]ardForum Junkie
    12,373
    Jan 14, 2006
    But again, thanks to "paid exclusives," AND the much more strenuous certification process for playing back HDCP 2.2 content on an open platform like the PC, you're often going to be stuck with a new Intel chip or nothing.
    Netflix 4k streaming was an Intel paid exclusive for six months.
    4k BluRay playback IS STILL a paid exclusive for Intel, after 12 months.
    Even after it's no-longer a paid exclusive, It's expensive to get your devices certified for each playback source. This is why Nvidia released their Netflix 4k drivers ONE YEAR before AMD, because they spent a lot more to move the cert process forward.
    https://www.pcworld.com/article/319...-on-geforce-gtx-10-series-graphics-cards.html
    https://www.trustedreviews.com/news/netflix-4-streaming-amd-gpu-drivers-download-3466303
    Even though RX 480 and GTX 1080 were released within a month of each other, with the exact same HDCP and HDMI specifications, it took one platform twice as long to get certified. That screams money required.
    I wouldn't expect this tiny company to pay very much for the cert process, so it's dead-in-the-water. If it can't play back legal content, there isn't much market for it.
  6. omegatotal
    omegatotal Gawd
    672
    Mar 15, 2002
    This is likely 100% Digital signage related. So that you can run more than 2/3 displays off a single intel SOC solution or similar.
    Will probably have next to zero actual acceleration and likely use the iGPU for nearly everything much like a USB2.0 or USB3.0 (to whatever you prefer) display adapter.
    Just with better quality than the usb ones.
