what would be a good video camera to use for a tv monitor? in our school, there is a smaller room next to the main room where we need to get a camera set up, but im not sure exactly what kind to get. just needs to be under $100.
You're just having it hooked up to a monitor, to view stuff? So the video quality doesn't matter that much? Get a used Hi8 or even S-VHS camcorder off ebay. Most of them have video outputs.
on a lot of the camcorders if you keep the tape slot open the camera will stay on.
I've got an old Canon 8mm camera that I would sell pretty cheap since the heads I believe are bad but the camera portion works fine.
I may have some other cameras as well, just need to look through my storage stuff.
If you are interested, let me know.
sorry i havent got back with you. if you can check and see if the camera stays on with the tape open or whatever, we may can work out something. lmk, thanks.
