Zarathustra[H]
Extremely [H]
- Oct 29, 2000
Hey all,
So my Fiance has started dropping hints that she could really use a laptop and since I handle the IT in the house, I've started looking around.
We are trying to save up for a down payment on a house, so this can't be something expensive, and she knows that too (she's been looking at the Groupon Goods deals in the $200-300 range and sending me links).
I've been looking through those listings too, but it's been an exercise in frustration, as I can't seem to find what I am looking for.
Her requirements:
I guess I'd be OK with soldered on RAM in a pinch, if there were at least 4GB of it, but I really hate that, and would prefer to have long term upgrade-ability in mind.
the 802.11ac is a requirement as I don't want the laptop to sabotage the house wifi by dropping it down in speed.
CPU power is not a huge deal within reason. I'd prefer to not get an Atom, but anything above that, I'd be OK with.
I have no issue at all with hacking a Chromebook if I need to, as long as it meets the rest of the requirements.
So, my issue is this. All the laptops I seem to be finding are either thicker/heavier higher powered models with 2.5" SATA drives and replaceable RAM, OR thinner, lighter models with soldered on flash storage and RAM.
Older Ultrabooks/netbooks and chromebooks used to have 2.5" drives and replaceable RAM, but these days everything thin seems to be consumer-deviceified.
Are any of you aware of any that still are made this way, and won't break the bank?
To sum it up, looking for:
Her requirements:
- 13" or 15" class
- Not too heavy/thick
- Absolutely must have upgradeable RAM and replaceable 2.5" drives
- Must have 802.11ac WiFi.
- 13" to 15" class
- Ultrabook / netbook / chromebook type thickness/weight (I'm fine with hacking a chromebook)
- Screen resolution at least 1366x768
- CPU power not a major issue. I'd take AMD or Intel, as long as its not a Atom type weak deal.
- Replaceable RAM
- Replaceable 2.5" storage
- 802.11ac
- $350 max
