What rezPath tracing looks good, to me. I'm running it all maxed out with DLSS Quality and no frame gen getting a solid 70 FPS in the Vatican.
He has 4k monitor in his sig but no way in hell he is staying at 70 fps at 4k with DLSS quality and no frame gen. Even on balanced it cant keep that framerate with maxed path tracing.What rez
I'm posting the pictures to show what I've seen to prove I'm not making shit up. I had absolutely zero reason to assume foul play and that the stream I watched would not be a good representation of how the game actually looks like.
When have steam concurrent players ever been unreliable?
If a game peaks on 5k on launch day that is not a good sign and we can absolutely make assumptions based on that.
If a game only gets 10K active players there won't be a million people who bought it just haven't played it either. It's not that I want the game to be a flop, I'm just calling it as it is.
Perfect game to play while they fix a few things with Stalker 2! So far this Indy game seems very polished and I haven't ran into gameplay bugs or issues.I have to wait and play more STALKER 2 before I get this … cause I probably won’t stop playing it.
Good to know! Maybe time to pivot to Indy.Perfect game to play while they fix a few things with Stalker 2! So far this Indy game seems very polished and I haven't ran into gameplay bugs or issues.
Probably running out of VRAM.My main issue so far, 12900kf/3080 im getting 100+FPS 3440x1440 with custom settings, but there is an every few second drop in FPS that comes across as a quick hang/frame drop while the game seems to move smoothly
Game pass version? If so then frame gen is supposedly broken on that version of the game.Game was jacked. I restarted it and now path tracing is magically running good. Frame gen is still broke for me though. If I leave it enabled after restarting the game it'll work, but has massive stuttering.
When you watch footage of a game your first idea is "Oh I must watch other sources as well because this might not be representative"? As I've said: I had no reason to distrust the source.It only takes you a few minutes to find other videos/screen shots, like the ones posted in this thread. Whatever streamer you watched was playing on a potato PC. I'm not sure why you're only using that as a reference point.
You can,see my video. I'm in Giza which is one of the more demanding areas and you can get 60fps 4K with DLSS Quality around the village otherwise it's 64fps+ most times. Balanced takes it up to ~85fps typical or 75 ish in the village.He has 4k monitor in his sig but no way in hell he is staying at 70 fps at 4k with DLSS quality and no frame gen. Even on balanced it cant keep that framerate with maxed path tracing.
Don't see why one should be surprised; it's made by machine games with id tech. Even bethesda knows better than to interfere too much.They should have called this game Indiana Jones and the Great Surprise, because it is doing just that across the board it seems.![]()
They clearly are surprised, though. Look at many of the replies.Don't see why one should be surprised; it's made by machine games with id tech. Even bethesda knows better than to interfere too much.
But the biggest surprise is that this 2024 game is practically indistinguishable from the original Mafia![]()
I am running the game at 3840x2160. Sometimes it will drop to 60 out in the open. It goes up to 80 in dungeons.He has 4k monitor in his sig but no way in hell he is staying at 70 fps at 4k with DLSS quality and no frame gen. Even on balanced it cant keep that framerate with maxed path tracing.
EDIT: Maybe Vatican area is not very demanding.
Thanks, ill mess around some more. I've tried everything to absolutely low and still get this stutter. Wondering if its a Game Pass version issue. Again, don't have this on any other titles I've played.Probably running out of VRAM.
What setting is your Texture Pool at?
Try it at High, and if that doesn't help, try Medium.
The Game Pass version is not up to snuff like the Steam version is last I heard.Thanks, ill mess around some more. I've tried everything to absolutely low and still get this stutter. Wondering if its a Game Pass version issue. Again, don't have this on any other titles I've played.
That doesn't surprise me. Palworld was the same; Gamepass was always a patch or three behind Steam.The Game Pass version is not up to snuff like the Steam version is last I heard.
I like having the Blackshirts bunch up on you, as long as you have any melee item equipped, you can hit multiples of them with one swing which is great since most clubs break after 3 swings.You can easily fake the AI out when they take a swing at you, allowing you to get free hits in. When they all come they tend to bunch up in front of you, so you don't have to worry about being attacked from the sides or behind. The only thing you need to worry about is getting shot in the back by Captains. You also suffer no consequences for repeatedly taking out all the Blackshirts and soldiers in a given area as they respawn when you come back. This is on the Hard difficulty setting (3rd out of 4). I want to try it on the hardest difficulty now.
Always been that way. But you gotta take some concessions when you get the game for a heavy discount or basically for nothing if you did the long term conversion.That doesn't surprise me. Palworld was the same; Gamepass was always a patch or three behind Steam.
It's been running fine for me since advanced access launch Thursday night.The Game Pass version is not up to snuff like the Steam version is last I heard.
I'm Excited about it, But i'm not buying some $100+ dollar edition to play early. Yeah, We see how starfield turned out, Look at the forum here for instance. So it's little wonder people didn't want to be fooled a second time just a year later.Because when people are really excited for a game they'll buy the ultimate edition. Starfield started on 220k players its early access period and peaked at 330k when the regular version unlocked. With sub 5k early access player count this game will be lucky if it can break the 10k barrier on the 9th.
m/kbAre you guys using a controller or a mouse/keyboard?
Mouse and keyboard.Are you guys using a controller or a mouse/keyboard?
Because I don't want to stand around for 3 seconds waiting for my character to turn or look up/down when you need to do that a lot in this game. I also don't ever recall the game telling me to use a controller.Controller. Why would anybody want to use a mouse and keyboard with this type of game? It even tells you that you should be using a controller when you start the game.
I can't see why anyone would use a controller period, let alone use one for an FPS game.Controller. Why would anybody want to use a mouse and keyboard with this type of game? It even tells you that you should be using a controller when you start the game.
