Yeah, I still use my 2010 PC and it works great. I do lots of encoding and I use it for surfing, watching videos, etc. I upgraded the RAM to 8 GB a while back and it definitely made it a lot more usable (it originally had 4GB which just isn't enough in 2022).
It is currently running win 7 with a Linux Mint dual-boot. That said, I have been told here that I should not be using Win 7 directly as my computer is likely compromised and contributing to the botnet problem because win 7 has become heavily exploited since it stopped getting service updates. I am planning to switch over full-time to an actively serviced LInux distro where I would like to run Win 7 within a virtual environment where it will be safer from exploits. I am not sure if win 7 will be fast enough to be usable within a virtual machine on such an old computer but I still want to give it a try.
Your anti everything not win7 is overblown. I never had windows update brick my install. If you had more modern hardware you would have less issues. You are hardcore knee napping that 3080ti with that CPU and windows 7. There is absolutely no reason to be still using windows 7. A retro box? Sure but not as a primary everyday gaming PC.The anti Win7 fear mongering here is very overblown. As long as you have a decent firewall, antivirus software and exercise cation and restraint on the internet, you'll be fine. Actually find it very refreshing to never have to come home to find Windows Update broke something again while I was away at work.
Depending on the motherboard and your willingness to mod, you could do a CoffeeTime mod and drop in an 8700K or similar for a cheap jump in performance! I wouldn't bother with a 7700k, any other 8th gen, or any 9th unless you get a deal or ES 9900K.5 year yeah easily. My server is built around a 6700k and does everything I ask of it no problem and that CPU was released Q3 2015 according to Intel's site so it's 7+ year old tech at this point (which feels weird to say considering how relevant it can still be).
Woah, I had never heard of such a thing for this gen of stuff 🤯 I haven't looked into it much but how is the risk factor? Any downsides?Depending on the motherboard and your willingness to mod, you could do a CoffeeTime mod and drop in an 8700K or similar for a cheap jump in performance! I wouldn't bother with a 7700k, any other 8th gen, or any 9th unless you get a deal or ES 9900K.
I've got a 9600K on a Z170 for instance, running a smooth 5ghz OC. Great board I had laying around, and a great 9600K, made sense to me.
I used my bios programmer and a software mod called coffetime, modded up some bios to make it take any cpu from 6th gen to 9th gen including ES, and then you just take some copper tape to jump a pin pad to tell it to take a coffeelake cpu.Woah, I had never heard of such a thing for this gen of stuff 🤯 I haven't looked into it much but how is the risk factor? Any downsides?
(I won't take this any further in this thread if I have additional questions, I don't want to totally hijack the thread lol)
Again there is no reason to be running 7 on a primary modern system. I see absolutely no benefit in it. Yea we still have a XP box at work to run out old CNC machine. It is not connect to the network either. Even my cheap ass company that pushes everything off as long as possible company pushed everything to windows 10 before EoL. Any way you do you.Good for you. I have a conga line of customers that disagree with you, including authoritative national news organizations that have been covering thousands of people getting bricked Windows machines from bad Windows updates for years. And Microsoft publicly apologizing and rescending several major updates because of it.
I used Windows 7 as my primary gaming machine well after it was EOL'd and had no issues. I still use it on my work laptop because of proprietary legacy software that doesn't work on Windows 10.
If you run a good ad blocker, security plugins and don't do dumb things like go to sketchy download sites, you'll be just fine on a Windows 7 machine if you're behind a good firewall. If you do something dumb like DMZ a Windows 7 box to the internet, or host a web server on it, then yes, prepare to be owned by Russian and Chinese botnets.
but I'm not convinced that playing your 25 year old games is really better on hardware from the period.
Wouldn't some of those work on dosbox ?Few other examples of games that don't work right, or at all:
Now you sure of that? I had a customer recently that had a bunch of Windows 7 machines that ran 'prop legacy software' from the turn of the century. He had been told by two other IT specialists that it would never work on Windows 10.I used Windows 7 as my primary gaming machine well after it was EOL'd and had no issues. I still use it on my work laptop because of proprietary legacy software that doesn't work on Windows 10.
Hmmm my 2016 x99 5960X with quad channel RAM still keeps up with the AAA big boys no problem. There is always a huge range in hardware from any period. It's just the lower end half that really turns to junk a lot faster than the rest.Does old hardware have a use? Beyond target practice, I think five to seven year old hardware still has some viability for ancillary uses or for extremely young children's games which aren't usually aren't all that demanding.
And old os are fun I just recently got a toshiba libeberata 50c running
Exactly. Between that and VM's, I see little reason to run games of that era on period hardware.
I laughed, took one of the machines home, cloned the 7 build to a SSD and then upgraded it to 10. Worked fine. All his machines are now on 10 and SSD tech. He was so chuffed he took me and my other half out for dinner!
Well I always say it's a 33/33/33 thing. Is it not also up to the manufacture of old stuff to keep it going? If they don't care then why should MS have to keep looking backwards? Also if something is that vital then shouldn't the customer also have the gumption to find a new solution and invest in it?It's sad how many Microsoft apologists there are today that excuse their widely documented faults, problems and abhorrent behavior and pretend everything is rainbows and unicorns.
99 times out of 100 in my experience, this issue is usually down to the customer being a tightwad. "I paid $1000 (most likely pirated) for this software back in 2002 and I've made $8,000,000 from it since then but I can't afford to find something newer or better! I need to sweat this asset till I retire! So sonny you need to keep this XP machine going!"
Yes and some of those are DOS game or at least I played them on DOS, like SimCity-SimCity 2000, has a rule if it is on the gog store:DosBox is for DOS games, not Windows. While DosBox can "run" Windows up to 3.x, it doesn't do it well.
Because Microsoft advertises the features as supported, when they don't work. If MS had said that they would be removing COM and Parallel port support, and removed all drivers for said devices, it would be another story. But as it is, they advertise support for COM and Parallel ports that don't work, and have no plans on fixing them.
This is entirely on Microsoft, it's not the job of the equipment manufacturer to fix someone else's software.
You're completely out of touch with reality.
Well thats abit pessimistic and out of touch with reality (similar to some of your other comments...). I took the thing apart it was a very neat construction and appears to use some pretty decent components. Take a look at the pcb below if you want. The small handful of "at risk" capacitors it has all apear to be in a decent condition. The screen, processor, perpetuals should continue working provided nothing drastic fails.Hope you recapped the entire thing, including the screen. Else it's not going to be working for long. I fixed up one of those a year or so ago, they're not easy to repair, especially after having all of the capacitors leak and destroy large parts of the logic board. God speed if the capacitors eat the boost converter section on the logic board that power the screen's backlight.
Can you believe this system is 11 years old now? 16 cores /32 threads, and 128GB of Ram.Does old hardware have a use? Beyond target practice, I think five to seven year old hardware still has some viability for ancillary uses or for extremely young children's games which aren't usually aren't all that demanding.
At 10+ years old, I don't think most hardware has any value outside the context of a museum. It should be thrown away, recycled if possible or shot. Retro gaming is something I honestly don't get. I think people sometimes make decisions that don't make sense based on feelings of nostalgia alone. When we are taking about old cars or guns, I can understand it too an extent, but I'm not convinced that playing your 25 year old games is really better on hardware from the period.
A lot of the high end old computers from 8 to 12 years ago are like old MOPAR stuff. They will keep up to a point but then passed by the latest and greatest from today. However, they will still blow away 75% of the rest of today's off the shelf computing. The only issue with old rigs like that is power consumption. That's why I tend to let them go, epsecially if they are no longer being used to do real crunch tasks. Just wasting money using it as a web/office machine.Can you believe this system is 11 years old now? 16 cores /32 threads, and 128GB of Ram.
I had one of those as well. It idled at around 300-350 watts with 128GB of DDR2. When I sold it I pulled out 96GB of ram since the client didn't need it and it lowered the idle power like 100 or so watts.A lot of the high end old computers from 8 to 12 years ago are like old MOPAR stuff. They will keep up to a point but then passed by the latest and greatest from today. However, they will still blow away 75% of the rest of today's off the shelf computing. The only issue with old rigs like that is power consumption. That's why I tend to let them go, epsecially if they are no longer being used to do real crunch tasks. Just wasting money using it as a web/office machine.
I remember having a dual CPU quad Xeon setup with 16GB of DDR2 ECC ram. Loved using it but I would be terrified at the power cost today. That DDR2 was a energy burner and I only had 8 sticks of it.
^^ that. I use thirteen year old Dell T3500 and T5500 systems (see signature) that I got for free and they are still quite relevant. Internet, movies, gaming, video editing, whatever.Of course. My PC is mostly 11 years old (aside from the GPU) and it still runs everything I've ever thrown at it. Plays all my games smooth from F.E.A.R. to Dying Light to Red Dead 2.
