In need of a monitor stand
50Cal
So i have a samsung tv being used as a pc monitor with a feet footprint of 30 inches. I've been trying to find a good monitor stand that will also allow for a center speaker to fit underneath. The center speaker is about 4 inches tall from the logitech z906 set.
I've had no luck finding anything that is both long and high enough. Is there anyone else here that is using the samsung tvs for their setup with a monitor stand? Or does anyone have some recommendations?
beyonddc
I can't find a good picture of my DIY monitor stand. Here's a picture of it from couple years ago, I am now using monitor mount so the monitor stand has been retired.
It is basically the wood board from a wall shelves and then two individual wood block I found from Lowes. I glued it together using wood glue. Nice and easy
If you are using a very long board then just add more wooden block underneath for support.
If you want to change to a different color, sand it and spray paint it. :)
