I have a older PC with a core duo and a HD4800 with a native VGA port, i was using it to play PS1 games on a AccuSync LCD 5V (1024x768) and on the HD4800 the picture was crisp and clear so a few days ago i decided i wanted to emulate more then PS1 games so i moved out the duo core PC and moved in my old 2600k system with a HD7850 and it only has digital ports on the back so i used a adapter to convert to VGA unfortunately the image now on my Accusync is really soft and washed out.
Before some one says just change the monitor, I would but my options are limited and this one is the right size and weight for what i need it for so i would like to know is there something i can do to improve the current setup in software or is the adapter im using just shitty or it this a fact of using VGA on DVI, if a different video card works better with VGA also let me know i have countless HD6950's and of course the HD4800 but that card is getting dated.
I appreciate any help with this matter.
