Cerulean
- Jul 27, 2006
Greetings!
I have observed this behavior on multiple Mac OS X systems from different organizations. Example: TeamSpeak server service is running, machine is connected to organization WiFi and also via wire by Thunderbolt adapter, TeamSpeak users are only able to connect to the TeamSpeak server using the WiFi IP address of the Mac even though both the WiFi and wired NICs are connected to the very same LAN. If WiFi is turned off, they can connect to the server using the wired IP address no problem, but is not true if WiFi is turned back on and reconnected to the wireless network.
Why? This problem doesn't happen in Windows as Windows will accept connections on either interface. I want to understand this behavior of Mac, why it happens, and if there is anything that I can do to modify that behavior.
Thanks!
Thanks!
