Originally posted by Ogre Warrior
Thanks for the helpful , if you read my post, you would have come to the conclusion that if I completely turned off my case fans my computer will overheat and leave a crater.
no it wouldnt. you need cool air in over the rad and something to push/pull the hot air OFF of the rad and thats it.
also w/c isnt about subzero temps, its about being to keep those completly perfectly fine temps while OCing heavily
**EDIT**I really don't think you want to get into the namecalling thingy, now would you? I altered the post...consider this one a freebie....MD
