IE 6 favorties
Dahz
the bane fo my reformatting is saving ym weblinks folder. i know where it is, and i back it up ebfore ir eformat, but after the reformat when ir estore the folder, all my links are now sorted alphabetically, which dosnt suit me or the way i prefer to have my links orginized.
now internet explorer will remmeber how i orginized my links once i manually move them, which leads me to belive there has to be some file somwhere that remembers how i orginize my links, and saves that for when the computer is shut down and such.
anyone know what that file may be, and where it may be found?
or am i just a little too hopefull for making my restoring from reformattings less irritating?
dbwillis
Ive never had the links return into IE in the same order as they last were,,
but its easier to do File, Import/Export, Favorites, to a .HTM file and then do the IMport on the new build...rather than copying the entire folder...
Same with cookies (passwords), Import/Export works great...
