Cov
- Dec 3, 2007
Hi, I am trying to put a list together of all personal adjustments after a fresh installation of Windows 7.
I'm aware that many people would not agree with all of these settings, but I have found it to be useful for my system with an SSD as a boot device.
Please have a look at my list and you are very welcome to comment and / or contribute with more suggestions of what might be useful.
How to modify UAC
Start user accounts change user account control settings adjust slider
How to disable Page File
Start system Advanced system settings Performance Settings Advance Virtual memory Change No paging file Set OK
How to disable Hibernation
Start cmd type: powercfg -h off enter
How to disable System Restore
Start System System protection Configure
How to turn off Search Indexing
a) Start services windows search disable
b) Start computer right click c drive properties untick: Allow files on this drive to have contents indexed in addition to file properties
c) Start Indexing options modify show all locations double click users in summary of selected locations uncheck users directory double click start menu in the summary of selected locations uncheck start menu directory ok
How to turn off Remote Differential Compression
Start Control panel programs turn windows features on or off uncheck Remote Differential Compression ok
This makes file transfers (copy, move) faster by turnig off Remote Differential Compression (RDC). Copying a 1.91 GB folder from the main HDD to a folder on an external USB drive resulting in ...
With RDC turned on: 3:23 - three minutes and 23 seconds (with a stopwatch).
With RDC turned off: 2:25 two minutes and 25 seconds.
How to turn off unneeded Windows features
Start programs & features turn Windows features on or off uncheck
· How to remove the recycle bin
Right click desktop Personalize change desktop icons untick recycle bin
· How to disable defragmentation & Superfetch
Start Computer Management or Services Disk Defragmentation disable
Superfetch disable
· How to change title text of Internet Explorer
Start regedit HKEY_CURRENT_USER Software Microsoft Internet Explorer Main
Look for Window Title Registry Key at the right pane. If its not there, create a String Value type of registry key and name it as Window Title.
Double click the Window Title registry key and enter the customized text that will appear in the IE window title.
· How to change border padding for windows
Right click the desktop Personalize Windows Color Advanced Appearance Settings select Border Padding change size 4 (default) to a lower value.
Windows uses 20% of your bandwidth, here's how to get it back
Start Run gpedit.msc (Local Group Policy Editor) Local Computer Policy Computer Configuration Administrative Templates Network QOS Packet Scheduler Limit Reservable Bandwidth ENABLE reservable bandwidth, then set it to ZERO OK
Disable unneeded start-up programs from loading
Start msconfig or system configuration services tab
How to access the Disk Management Console Tool
Start diskmgmt.msc
· How to display system information
Start system information
Turn off automatic update
Start Windows update change settings never check for updates
· How to clean the HDD / SSD
Start cleanmgr (or use CCleaner)
· How to access Resource Monitor
Start Resource Monitor
Windows 7 - Supercharged
How to modify UAC
Superfetch disable
Start diskmgmt.msc
