Hardware:
Lian Li PC-Q25B
ASRock A75-ITX
AMD A8-3870K
Seasonic SS-460FL
GSkill Ripjaws 16GB Kit
Noctua NF-P14
1 OS SSD, 1 L2ARC SSD, 1 ZIL SSD (might combine some of this, not sure yet)
The case will take 6 drives and I plan to fill it with 3 or 4TBs. Basically, I just need the controllers - the board has a PCI Express 2.0 board for this reason.. I don't necessarily need the overkill of an Areca 1k raid controller, just something that will be supported. I might like ESXi support down the road but not necessarily initially. Looking at OI/Nexenta.
Maybe something like: http://www.newegg.com/Product/Product.aspx?Item=N82E16816118112 ?
Lian Li PC-Q25B
ASRock A75-ITX
AMD A8-3870K
Seasonic SS-460FL
Noctua NF-P14
