icons look weird in dvd drive
dragnandy
im sure if it affect it, but im using stylesXP to add/edit themes for windows XP. this has been there for a while now, but i decided to try and fix it but cant find a solution. for some reason, when i open the dvd drive, in this case the D: drive, the icons are covered by the IE icon. heres a pic.
does anybody have a suggestion on how to fix this? if you look closely, you can also see that the folder icon is behind the IE icon. I can still open the file and everything works the way its suppose to.
