Computer was a Company Spare and was just powered up by me a month ago. Computer specs are :
Pentium 4 3ghz Hyperthreading processor
512MB Ram
80 GB 7200 RPM performance Hard Drive
Intel 865p Chipset with integrated Intel 3d Graphics
Windows 2000 License is included (Currently has XP Professional)
Built in Sound card
3, 1394 firewire ports (add-on card)
8, USB 2.0 ports
DVD 48x CD-R CD-RW Combo drive
3.5 Floppy
Factory Warranty until 11-09-2006
$600 Shipped
Montor was just receved by IBM 2 weeks ago and is in perfect shape with no dead pixels. Sells for $500 online. Monitor is under the factory warranty until 6-23-2007!! $350 shipped
The ThinkVision L170p 17-inch LCD flat panel monitor delivers excellent performance for a variety of applications at an optimum resolution of 1280 x 1024. It incorporates IBM ThinkVantage(TM) design that enhances usability and complements the system design. The ThinkVision L170p is a Performance flat panel LCD in IBM's ThinkVision family of monitors.
Features
Ergonomic stand swivels, tilts and provides height adjustment of 100mm for optimal viewing comfort
Quick and easy monitor adjustments using new designed On-Screen-Display (OSD)
Cable management in the stand
Contrast Ratio: 500:1
IBM Preset Modes: 20
Recommended (max) Resolution: 1280 x 1024
Max Vertical Refresh rate: 76 Hz
Min Horizontal Refresh rate: 31 kHz
Slowest vertical refresh rate: 55 Hz
User programmable modes: 15
Video inputs: Analog / digital (DVI)
Dimensions: 15.7" (W) x 18" (H) x 9.3" (D)
Weight: 12.6 lbs
Supported Software Applications: Windows ME / 2000 / XP
Power consumption: 40W
512MB Ram
Built in Sound card
8, USB 2.0 ports
3.5 Floppy
$600 Shipped
Features
Weight: 12.6 lbs
