i9 10850K vs i9 10900
chong678
I am about to build a new computer for myself and I want to do it right.
The price is the same for both of the CPU above.
Scenario : I do not overclock my computer. I don't like the extra noise fans, etc etc
1. Should I just get the 10900? When not in load, it always run at 2.8 Ghz and it saves on the power bill.
2. When in load, it can run up to 5.2 Ghz right?
Thanks for your help.
munkle
they are basically the same processor, if they are the same price get the 10900.
zandor
i9-10900 or i9-10900k? The i9-10850k is faster under heavy loads than the i9-10900, but draws more power at official Intel settings under a heavy load. The official long term power limit for the i9-10900 is 65W, while it's 125W for the i9-10850k.
Don't worry about idle power draw. Any modern CPU clocks down way below 2.8GHz when idle.
Both the 10900 and 10850k can turbo up to 5.2GHz, but that's the max for 1-2 cores. The i9-10900k can turbo to 5.3GHz. If more cores are loaded they won't go that high. CPU performance these days, especially for Intel CPUs, is largely about power and heat. Give any of these three chips better cooling and allow them to consume more power and they will go faster when heavily loaded with a bunch of threads. With only 65W at stock settings the 10900 won't run as fast as the 125W 10850k under a heavy load.
That's stock settings though, and pretty much any motherboard lets you change them. On top of that, "everyone but Asus" tends to disable power limits by default, so MSI, Gigabyte and ASRock boards typically let the CPU have as much power as the board, cpu and cooling can handle. You'll want to either set the power limits on those boards to stock for whatever CPU you are using or set them to something your cooling system can handle without getting too loud or letting the proc get too hot. I'd do the latter.
munkle
Good point I was thinking 10900k for some reason
chong678
zandor Thanks for your input.
The 10900 and 10850K are both the same price. I mainly use my computer for virtualization. I use VMware and I normally have 3 instances running. I also do photo editing. Which processor is good for me? Thanks.
MrGuvernment
This will tell you all you need to know, the 10850k can use up to 20watts more as soon over the 10900k, since the 10850k is binned 10900k that didnt meet the strict requirements.
https://www.anandtech.com/show/16341/intel-core-i9-10850k-review-the-real-intel-flagship
D-EJ915
10850k is more powerful (125w) with higher boost clocks, 10900 puts out less heat (65w) and lower boost clocks. Which would suit better to you workload, both probably would work fine so difference to me would be do you want a quieter and cooler system or louder and hotter?
chong678
Which of these 2 processor would be great performance with three virtual machine running?
