Question as in title. Was wondering if you guys hit 3.2 without having to adjust voltage and any other settings? I've only done overclocking back in the AMD X2 days, and back then it was pretty simple, you essentially had:
- an FSB/Hypertransport speed, which scaled the memory (and with the memory speed)
- a ratio (1:1, or less, if your memory couldn't run fast enough)
- a multiplier
- a CPU voltage
Are there any new aspects / things that have changed that I should worry about when trying to do 3.2? Also, is the stock HSF good enough for 3.2?
- a multiplier
- a CPU voltage
