Karn-
- Jun 4, 2016
hi all, here's a bit of a rundown - thanks for taking the time to read if you stick around
Specs:
i5-6600k
Noctua NH-d14 w/1151 mounting kit
MSi z170a pc mate w/latest bios
Corsair LPX 2x8gb DDR4 2133
EVGA GTX 970 ACX 2.0
Corsair Force GT 120 SSD w/up to date firmware
1tb WD black drive
1tb WD green drive
Corsair TX750 psu
Corsair 500r case
I went from an AMD 8320 and an asus M5A97 to this intel setup about a month ago, and for 3+ weeks I didn't have a single issue - clean install of windows, DDU graphics driver install, chipset drivers and bios and firmwares all up to date. played games for hours and day to day use was 100% stable.
This was at a 4.5ghz overclock, with the ram running at 2400 with slightly lowered timings. it was fantastic.
Then, seemingly out of nowhere, I started getting bluescreens with IRQL_NOT_LESS_OR_EQUAL.
I couldn't figure it out, and then it went away for a couple days so I left it alone.
Then they came back, and worse, the computer would just hard lock and not bluescreen, and the reset button would not work. I had to hard power off and boot back up.
I spent some time looking through dump files with whocrashed, looking at eventviewer and msinfo32, all to no avail. The dumps always said the same thing.
Eventually, upon a hard lockup, the computer would go into an "overclocking failed" boot loop, even if I set the bios to optimized defaults.
This is where it got weird, because at this point I decided to start fully troubleshooting which meant turning off all overclock or such related settings and starting to crackdown on these crashes.
Didn't matter, still got the "overclocking settings failed, please run setup" boot loops, of which I could eventually get into windows and the system would then run for an arbitrary time before crashing.
So onward to testing
Memtest passed with flying colors for both sticks, together and individually.
Stress tests and the intel cpu diagnostic program all passed. Nary a single hiccup or temperature issue or lockup.
And then I would crash while reading a reddit thread listening to music, with no games or stress tests running.
I cannot for the life of me figure out what this is. I've reinstalled windows, I've done all the tests, I don't have any strange software or USB devices hooked up, my ram passed memtest and is on the compatibility list for my motherboard, my temperatures OC or not are 100% fine (4.5ghz overclock never passed 60c under full load, thanks noctua!) and all my bios/firmware/drivers are clean and up to date.
This is becoming a serious issue because the crashing can go days without happening, and then happen within minutes of booting for an entire day with no relent, regardless of overclock or devices or anything else.
Here is some of what whocrashed has spit out amongst crashes, if you guys need anything else please let me know, I would really love to get this figured out as I don't really have the option to just start replacing parts.
____________________________________________________
On Mon 5/30/2016 9:24:35 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\053016-6578-01.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0xC000021A (0xFFFFC000C4863700, 0xFFFFFFFFC0000428, 0x0, 0x15C91210000)
Error: STATUS_SYSTEM_PROCESS_TERMINATED
Bug check description: This means that an error has occurred in a crucial user-mode subsystem.
There is a possibility this problem was caused by a virus or other malware.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sat 6/4/2016 7:07:34 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\060416-6109-01.dmp
Bugcheck code: 0xA (0xFFFFF803207A0A10, 0x2, 0x1, 0xFFFFF8033051FB10)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
crash dump file: C:\WINDOWS\memory.dmp
I've also attached the two dumps, just not the memory.dmp because its 650mb.
Hope you all are having a great weekend, thanks for reading.
Specs:
i5-6600k
1tb WD black drive
1tb WD green drive
Corsair TX750 psu
Corsair 500r case
