Well, I've discovered that my WRT54GL with Tomato (and even worse with DD-WRT) is struggling to keep up with my torrent habits. With uTorrent open, my Internet connection just slows to a crawl. I have tried a plethora of different settings, mostly dealing with QoS, but it just doesn't cut it. The WRT54GL has a limited amount of memory and processing power.
So, I've come across the Intel D945GCLF board with an integrated Atom 230 processor on it. It should be considerably faster than I'll ever need for a router. I'd demote my WRT54GL to wireless-only duty as an access point, with the data being sent through the Atom router. So, I was wondering two things: first, is this the best solution for me? It's quite cheap at ~$60, roughly the cost of my WRT54GL when I bought it, so what else would compare at this price range? Second, what software and/or OS should I get to do this? QoS is important, and if possible, I'd like to "throttle" P2P connections when they are taking up my entire bandwidth while another connection (ie. http) is attempting to connect.
I mean, I can pretty much wing it and put something together, but I want an informed opinion about what the BEST solution is.
