I updated my mobo firmware.. Now Windows 7 no longer works?
Discussion in 'Motherboards' started by ZodaEX, Oct 27, 2018.
  1. horrorshow
    horrorshow [H]ardness Supreme
    5,639
    Dec 14, 2007
    Yessssurrrrrr
    CAD4466HK likes this.
  2. yee245
    yee245 Limp Gawd
    177
    Mar 12, 2007
    Just a thought, but if you're having issues getting through the W7 install process because the keyboard/mouse aren't working in the installer, have you tried installing W7 onto the SSD while in another system, then just swapping it into the Gigabyte system?
    elite.mafia likes this.
  3. GeneO
    GeneO Limp Gawd
    233
    Mar 1, 2012
    For the USB mouse/keyboard issue, try setting XHCI Hand-off to enabled in the BIOS.
    I believe even though you are using USB 2.0, they are part of the USB 3.0 controller. USB 3.0 is not native to Windows 7, so you have to tell the BIOS to hand-off the USB control from the BIOS to the OS so it can use drivers for it. If it is enabled, try disabled.
    Also, is your install CD Windows 7 SP1? I think you need SP1 for the USB drivers.
  4. ManofGod
    ManofGod [H]ardForum Junkie
    9,768
    Oct 4, 2007
    I doubt it, to be honest. More than likely, the drive interface setting has changed, since updating the bios usually means all the settings are reset back to default. Try the IDE, AHCI or Raid until your Windows 7 install boots. Enjoy.
  5. DejaWiz
    DejaWiz Oracle of Unfortunate Truths
    18,277
    Apr 15, 2005
    What USB ports is everything being plugged in to when you attempt to install Win7?
    1. Keyboard
    2. Mouse
    3. Flash Drive with Win7 installer
    Oh, and what brand/model of Flash Drive are you using? If it's a USB3, try an older USB2 drive.
  6. ManofGod
    9,768
    Oct 4, 2007
    Bingo on that part. Chances are, the installation media does not have the required usb drivers.
    DejaWiz likes this.
  7. GeneO
    GeneO Limp Gawd
    233
    Mar 1, 2012
    He already stated that he was using the USB 2.0 ports. As I already stated, it doesn't matter what port because the USB 2.0 ports are part of the Intel USB 3.0 controller so he needs the USB 3.0 drivers on the installation CD, as I already mentioned. Either he needs the SP1 installation CD or needs to inject the USB drivers.
    DejaWiz likes this.
  8. mvmiller12
    mvmiller12 Gawd
    512
    Aug 7, 2011
    I have run into this problem with Windows 7 installer and USB myself. The easiest fix, of course, is to just Run Win10, but he doesn't want to. That leaves the harder fix.
    Using a different (working) computer, you will need to download or create a Windows 7 custom ISO with the SP1 and roll-up pack integrated. You may also need to integrate your chipset drivers in the installer. There are numerous tuitorials on the web (a simple Google search) on how to do this. You then burn the custom ISO to a DVD-R or put it on a USB stick with RUFUS.
    DejaWiz likes this.
  9. DejaWiz
    18,277
    Apr 15, 2005
    There are two USB2 and one USB3 ports on his system.
    The potential easy way out would be to plug the KB and older USB2 flash drive into the USB2 ports and run the install without a mouse.
  10. horrorshow
    5,639
    Dec 14, 2007
    *learned something new* (thanks)
    Can't he just salvage a sata dvd drive from somewhere and use it for like an hour? (at this point the whole exercise is becoming kinda retarded)
  11. DejaWiz
    18,277
    Apr 15, 2005
  12. GeneO
    GeneO Limp Gawd
    233
    Mar 1, 2012
    if you read what I said, the USB2 ports are part of the Intel USB3 controller. Doesn't matter whether you use USB2 or USB3 in this case, you need the driver for the Intel USB 3 controller.
    And if you read the OP posts, he dis try the USB2 ports.
  13. H2R2P2
    H2R2P2 Limp Gawd
    387
    Jun 18, 2006
    This is an easy one... Its either your RAID/SATA setting or your CSM/UEFI being enabled, disabled, or partially enabled.
    Since its sees your boot drive, it should be your RAID/SATA setting. Just switch it form whatever it is now to the other one and it will work.
    ManofGod likes this.
  14. DejaWiz
    18,277
    Apr 15, 2005
    Yo ease up...I wasn't challenging you, I was adding to your post.
    Being that this is an older Bay Trail SoC, I was simply saying that a USB2 flash drive should be tried prior to the efforts needed in taking your suggestion of slipstreaming the USB3 drivers, since he's sticking with Win7.
  15. GeneO
    GeneO Limp Gawd
    233
    Mar 1, 2012
    He has been using the USB 2.0 ports. What benefit is a USB flash drive if it is the same image. He needs the USB 3 drivers for the USB 2.0 because the Intl xHCI controller supplies the USB 2.0 and 3.0 ports and hence you need the xHCI driver for both.
    ZodaEX likes this.
  16. ManofGod
    9,768
    Oct 4, 2007
    Here is the important part, try to keep up. :D : I was simply saying that a USB2 flash drive should be tried
  17. GeneO
    GeneO Limp Gawd
    233
    Mar 1, 2012
    Your the one that needs to keep up but it is obvious you do not understand the problem. Later.
  18. DejaWiz
    18,277
    Apr 15, 2005
    I've run into the problem numerous times, myself. More often than not, switching to an older USB2 flash drive to force EHCI mode is the cure.
    Switching to EHCI is even stated in the spec update sheet...page 28.
    https://edc.intel.com/Link.aspx?id=7123
    As I stated before, I was merely adding to your post...try a USB2 flash drive first and, if that still doesn't work, then download the embedded driver package and slipstream it, as you recommend.
  19. Master_shake_
    Master_shake_ Little Bitch
    7,088
    Apr 9, 2012
    mvmiller12 likes this.
  20. maxius
    maxius 2[H]4U
    3,335
    Dec 17, 2001
    secureboot/tpm?
  21. elite.mafia
    elite.mafia Broke Back [H]
    10,650
    Aug 23, 2004
    According to a google search this board's BIOS needs to be set to whatever OS you are using before installing it. Have you tried that? based on the thread it sounds exactly like a incorrectly configured bios.
  22. elite.mafia
    10,650
    Aug 23, 2004
    Looking at google images it looks like a standard laptop style sata cable. I don't think it's soldered in, just taped in...
  23. ryan_975
    ryan_975 [H]ardForum Junkie
    13,748
    Feb 6, 2006
    And none of you seem to realize it's been nearly a month since the OP last replied? I'm sure he's either fixed it already or given up.
  24. Segfault
    Segfault n00bie
    9
    Oct 27, 2018
    Isn't Windows 7 terribly old? I think I had windows 2000 (it was my last Windows), seven must be much older than that.
    drescherjm likes this.
  25. ryan_975
    13,748
    Feb 6, 2006
    ummm. is this a joke? Windows 2000 (NT5.0) is ten years older than Windows 7 (NT6.1)
  26. Nokturnal
    Nokturnal [H]Lite
    121
    Sep 1, 2006
    with those web address skills...you must have gotten a lot of BoC's from woot.... LOL
  27. Furious_Styles
    Furious_Styles Gawd
    946
    Jan 16, 2013
    lol, time to get the time machine out.
  28. cyberguyz
    cyberguyz Gawd
    706
    Aug 28, 2014
    This made me giggle.
  29. kamxam
    kamxam [H]ard|Gawd
    1,454
    Mar 2, 2005
    I actually had the same thing happen to me when trying a Vista disk on my new setup. (Had lost my better Windows disks and it was all i had atm) I did manage to download a Windows 10 ISO to a USB drive from my laptop and that finally let me install it to my main system.
    Like was said, the OP hasn't answered, but couldn't he put in 10 to get it to the desktop THEN re-install Windows 7? Never tried it that way so not sure....
  30. ZodaEX
    ZodaEX 2[H]4U
    3,490
    Sep 17, 2004
    My main issue is that updating my motherboard's bios broke my perfectly working Windows 7 install. Installing to a different PC and moving the drive over wouldn't fix it, otherwise my functioning Win7 install never would have stopped working in the first place.
    Yes as i've already explained in great detail in post #14, I have tried both the SP1 integrated install disc, as well as the original day-one Win7 release. Keep in mind I have installed both of them in the past to this machine with zero issues until after I updated the bios.
    As this computer only has one single sata port, raid is not supported by the motherboard. Raid needs a minimum of two drives to function. As for AHCI and IDE mode, i've tried both and neither keeps my mouse and keyboard working during Win7 setup.
    Flash drive? I'm not using a flash drive. The way that I originally installed Windows to this machine was via a USB DVD drive. If it worked with a DVD drive the first time I installed Windows then shouldn't it work for the second time? Keep in mine I just bought a second external DVD drive and tested both on another PC to rule out the possibility of hardware failure of the optical drive.
    The keyboard has been primarily plugged into one of my two USB 2.0 ports and the mouse i've tried plugging into the USB 3.0 port, or not at all because, you don't need a mouse to install Windows. The bios update is keeping Windows 7 from booting or installing so at the moment that's my issue.
    It couldn't be that, because Windows 7 naively supports standard USB keyboards and Mice. In fact..... So does Vista, XP-X64, XP and even Windows 2000. I'm surprised that you would have thought that..
    If this is true, then how could I possibly have installed Windows 7 to this machine in the first place? What you're saying makes no sense given this. And the USB 3.0 port used to work for installing Windows before eveything went to hell so what you said is double not true.
    Do you have a source/citation that the Windows 7 rollup pack is required for the Intel Baytrail chipset drivers? My installation of Windows 7 was 100% fully updated when this firmware update caused it to no longer be able to boot. Since the machine already had the rollup pack on it prior to it breaking, your advice couldn't possibly fix it if it was an issue of chipset drivers.
    I have been plugging the KB into the USB2 ports.. The problem is that they stop working the moment the Windows 7 installer comes up.
    Sure! I can, that's no problem. However.. My board has one single SATA port. When I unplug the hard drive to connect the DVD drive, where do I then connect the hard drive so the bits of data can get in?
    Well this PC doesn't have raid settings since it only has a single sata ports. You need at least two drives to support raid. I have tried both SATA and AHCI mode and nether one will fix my keyboard from dying during the Win7 setup. Just to through this out there because I get the feeling you didn't read the thread: Ubuntu Linux also won't work unless I roll back to a super old bios version. As far as i'm aware the latest build of Ubuntu supports IDE and AHCI mode on mainstream Intel chipsets like mine.
    What makes you think that a flash drive would be necessary, seeing as how i've installed Windows 7 via DVD drive to this machine in the past before? Also if it was in issue is just lacking a driver, don't you think Ubuntu Linux would have worked, since this hardware is from 2013-2014? Surely Ubuntu has has enough time to build the driver's into it's image. (it has, i've ran it on this machine in the past before the firmware of doom)
    I've tried it with secure boot on and off. No difference either way. I'm not sure what tpm is, but i'll look for it the next time I take a stab at this problem. (considering selling this and buying an old Zotac z-box at this point. I don't trust gigabyte anymore)
    It sounded like that to me too, but it ended up being quite the doozy. (It usually is though if I can't figure it out on my own)
    And yes, the bios was set to Windows 7 mode. It was also already set to Windows 7 mode before the firmware hosed the PC. Didn't seem to prevent the problems, or fix them after clearing to safre defaults and re-choosing Windows 7 again.
    I haven't totally given up, but after spending an over 14 combined hours intensely trying to restore this computer to working condition I needed a breather. I feel that Windows 10 is being forced up my ass and it's gotten me stressed out as usual.
    This thread is long enough as it is. If you have nothing to contribute please don't threadcrap, making it harder on everybody to see the 10 posts where I mention that my motherboard has one sata port and that i'm only using native USB 2.0 ports.
    As i've already explained in post #6 with great detail, Yes, I can put in a Windows 10 disk to get it to the desktop. How in the world is this supposed to help me get Windows 7 re-installed though? The even bigger issue is this: Even if Windows 7 was installed, or Ubuntu for that matter, it won't boot.
    I had a perfectly functioning WIn7 install when everything went to hell. The problem is the motherboard now won't load it, or let me re-install it. (if I downgrade the firmware I can install Linux, but that's nether here nor there.
  31. mvmiller12
    mvmiller12 Gawd
    512
    Aug 7, 2011
    I don't believe the rollup being integrated is required to make this work, but it will sure make your life a ton easier to get updates after installation. Windows Update changed at some point, and without the rollup, it can take literal days to update all the way back up, largely because it will sit on the "searching for updates" screen for hours and then sit on the installing updates screen for more hours (with little indication of progress). It's terrible slow.
    That said, I do believe the integrated chipset drivers will be required to make it work. It seems fairly obvious that the BIOS update changed the USB IDs and thus Windows 7 can no longer recognize the ports without help. If the ports were actually borked, the Windows 10 installer wouldn't see them either. And if you're already going through the effort to integrate the chipset drivers, you might as well integrate the rollup into SP1 as well.
    Another possibility would be to purchase a USB 2.0 add-in card, if you have a slot open to accommodate it. Those tend to be really cheap if you don't already have one available to you, and should do the trick without futzing with creating a new custom Windows 7 installer.
    ZodaEX likes this.
  32. cybrnook
    cybrnook [H]ard|Gawd
    1,462
    Jan 14, 2013
    I didn't read the entire thread, but I have seen this and it was common. Basically what happens is the driver for the USB port you have your KB and Mouse plugged into are not being loaded. So what I normally do is unplug them and try to plug them into the back of the MB, preferably the USB 2 ports. Windows 7 doesn't natively understand USB 3 without a secondary driver. I also know some BIOS's offer a "Legacy" USB mode for compatibility. Could be this was now set to off as a default.
  33. ZodaEX
    ZodaEX 2[H]4U
    3,490
    Sep 17, 2004
    I know that you seem to think that WIndows 7 can't naively understand USB 3.0 , however mine can. I'd put my life on it as i've done it over and over and over again on this computer. Not that it matters, because i'm using a native USB 2.0 port anyways.
  34. ZodaEX
    ZodaEX 2[H]4U
    3,490
    Sep 17, 2004
    Can we talk about Ubunu Linux for a moment please? Perhaps it will help us step back and understand the bigger picture of why this PC is Windows 10-only now.
    If I try to install Linux, or just use the live-DVD environment, Linux will not load successfully, but I am greeted by hundreds of thousands of error messages. This does not happen on Windows 10. Do you guys have the same theories as before on this? Do you think Linux is also being stopped by a USB hardware ID change? Any other ideas?
    And how about the biggest mindfuck of them all? lol. If I roll my firmware back to version F8, then Linux works. But why if Windows 7 still won't work?
    It seems obvious, given these facts that the potential USB hardware id change isn't breaking Linux AND Windows from working so which one is it? Is it breaking Linux or Windows? I know it's not both because if it was, then my mouse and keyboard wouldn't work in Ubunu Linux either when I roll the driver back.
  35. mvmiller12
    mvmiller12 Gawd
    512
    Aug 7, 2011
    I can't speak to Linux as I am not a Linux guy, but the firmware for the USB controllers is separate from the mainboard firmware. This does not mean the the gigabyte firmware could not have updated it, but would perfectly explain why downgrading the firmware would not roll it back. It's entirely possible that the USB controller firmware was only EVER updated by that latest mainboard firmware update, with the USB firmware having been static since initial manufacture of that series of mainboard. Thus, rolling back the mainboard firmware would have no effect on the USB firmware - there's nothing there to roll back TO.
    Not directly relevant, but shows I feel your pain: I had to manually update the Asmedia USB 3.0 firmware on my old Asus M5A97 EVO mainboard to get it to work correctly with my Corsair K70 RGB keyboard. Asus never bothered to update the USB firmware with the mainboard BIOS, so I was looking at doing it this way or buying an add-in card at the time. The process for getting this done was both obscure and a pain in the ass. I had to find the actual Asmedia controller firmware stuff on Asmedia's Chinese website (and it was buried, man. Buried), and then run the update from FreeDOS. The firmware files were meant for add-in cards, not mainboard integrated controllers. I actually ended up flashing the wrong USB firmware by accident and killing ALL of my USB ports until I managed to flash in the correct one courtesy of another computer in the house for downloads and to burn a FreeDOS ISO to CD, a PS/2 style keyboard, and a bootable SATA CD Drive on the effected system. The problem was that there were 2 or 3 different "revisions" of the controller chip, all with the same model info. It was a nightmare, but in the end, I got the controller updated and my K70 worked fine on that system until I retired it in favor of my new Ryzen goodness. If I had it to do over again, knowing what I know now, I'd have just bought the fucking add-in card! :)
    ZodaEX likes this.
  36. ZodaEX
    ZodaEX 2[H]4U
    3,490
    Sep 17, 2004
    Wow that both gives me a bit of hope and also opens my eyes to all sorts of potential problems I never knew existed. I sure wish I had the option to use an add-in card but this PC doesn't have expansion slots. I'll take one more stab at this problem later when I can get around to it. In the meanwhile I've made myself another HTPC our of spare parts I had lying around. If I can't fix this Gigabyte computer within the next 4 hours of me working on it I should probably just cut my losses, sell it and buy a cheap used Zotac mini pc to replace it I think.
  37. mvmiller12
    mvmiller12 Gawd
    512
    Aug 7, 2011
    Your best bet, then is to keep your BIOS on F8 and make a new Windows 7 installer with SP1, the chipset drivers (specifically the ones involving the USB controllers), and the roll-up all integrated. It is more irritating to do than actually difficult, and you'll appreciate having a full updated installer if you plan to stick with Win7 for a while, so worth a stab at it in any case. Good luck!
    Here's a good place to start, I think: https://www.intowindows.com/how-to-integrate-drivers-into-windows-7-installation-disc/
    Edit: Oh! And keep us posted as to whether or not you get it working, and what ultimately got it going! I hate cliffhangers :)
    ZodaEX likes this.
  38. ryan_975
    13,748
    Feb 6, 2006
    This is good point. I believe in this case the USB stuff may be handled by Intel Management Engine* firmware (which is separate from the main firmware). It's usually updated with the main system firmware, but if memory serves I don't believe it can be rolled back (I could be wrong on that though).
    *ME firmware runs on an embedded processor inside the PCH (i.e. chipset) and handles the very low level initialization of the PCH and CPU before the main firmware starts. Without it the system does absolutely nothing, not even look for what to do.
    ZodaEX likes this.
  39. ZodaEX
    ZodaEX 2[H]4U
    3,490
    Sep 17, 2004
    I've got a good feeling about this possible fix. I'll definitely try it and report back how it goes.
  40. cybrnook
    1,462
    Jan 14, 2013
    And keep in mind you can always use something like NTLite : https://www.ntlite.com/ to just slipstream your driver into your installer and hopefully light up your USB ports during initial initialization of install, replacing the older likely outdated driver that comes in the default windows installer back from 7 SP1 days which may be incompatible with the updated firmware of the controller.
