I took a picture 2020
IdiotInCharge
NVIDIA SHILL
My wife just started baking, this is a product of cake #2 after years of watching Master Chef and other cooking shows (often rebinging them...)
EOS M5 | 28/3.5 | 1/60 F/11 ISO100 with an attached flash firing up​
leezard
Posting my blue angels photo again after some post processing. I didn't do the editing, I'm still learning how to work with raw images. A photographer I met discussing the flyby on the Nextdoor app did the post processing. I was pretty happy with my original photo, he kicked it up a few notches.
MN Scout
Thanks to the Corona Virus I got around to developing some film from my hike up to Ely's Peak in Duluth, MN back in 2018. I developed the Tri-X 400 film myself in Caffenol C-L. I used 3g/L KBr restrainer. 5 minutes of presoak with distilled water. 65 minutes of developing in Caffenol C-L using tap water. Agitated fully first minute. Then 3 inversions at the minute marks: 2,4,8,20,40. Stopped with water, Fixed for 5 minutes in Ilforth Rapid Fixer. 15 inversions top of every minute then rest for 45 seconds. Last, final wash in distilled water with 1/4tsp of Ilford Ilfotol so I wouldn't get streaks or drying spots. The negatives came out well. They weren't thin. The 3g/L was a bit of a mistake. I planned only to use 1.5g/L, but I was mixing this late at night, and forgot to half it when mixing up my 500ml of developer. I think I used a yellow filter on the last photo.
General trail:
Scramble down this boulder field:
Nebell
A few more motorsport photos.
Honestly I'm getting a bit tired of Porsche and BMW cars :rolleyes:
Nebell
I'm curious, is this allowed in the US? ;) (or in your country if you come from outside)
My friend was like "you'd get beaten up if you did that in Serbia" haha
The last car was very interested in what I'm doing, but they didn't say anything :LOL:
Taken in Sweden.
MN Scout
Film: Ilford HP5 400 Plus. Shot at ISO 266, since it is an unknown age. Guessed it was new back in 2010. Since it is BW film, I removed less than a full stop of sensitivity.
Camera: Pentax Spotmatic
Development in Caffenol C-L. Same routine as my previous post.
Scanned with CanoScan FS-4000 US, SCSI connection paired with Vuescan T-max 100 = 0.4. Contrasted and leveled in Lightroom.
I used the built-in meter. I notice that the meter has recently stopped working when set to 1/250th second. Maybe it just didn't like using that ISO combination. I've been trying yellow and red filters. So far I haven't been super impressed. I think it is because the camera meter is correcting. I need to try using my handheld exposure meter.
Jack-in-the-pulpit. Shot at F/5.6 using a 28mm lens. I took another shot at F/16 thinking that I needed the depth of field, since I was so close. The F/16 had more of the background in focus, but the plant was tough to see. This F/5.6 shot looks significantly better. Surprised. I'm learning that F/16 is not ideal sharpness when combined with 4000dpi scans. F/11 or less is better.
3 frames combined in Photoshop:
MN Scout
2020-05-24 - Pontoon and Garage - Taken with Holga Wide Pinhole Camera and on Seagull VC-FB pa...jpg
Photo of house take on Kodak 3A at U.S. aperture 128 and 23 seconds. Was partially shady and dim side of house.
Photo of Pontoon, and Garage taken with a Holga Wide Pinhole Camera (WPC) at aperture f/125 0.3mm at 23 seconds and it was almost full sun.
These were metered for ISO 4.
Notice: I have limited experience with this, so you are on your own if you follow this list of things I did and your prints turn out good or bad.
The paper was Oriental Seagull VC-FB II Glossy photo paper.
Developed with this Caffenol Recipe taken from http://tom-overton-images.weebly.com/caffenol.html
High Octane Caffenol Film/Print developer:
Water 8oz.
Washing Soda 3tsp
Instant Coffee 6tsp
Vitamin C 1tsp
House print developed first to a count of 400. Constant agitation - I kept lifting up a corner or side to keep the developer gently sloshing side to side. Long time because this is fiber based (FB) paper.
Then placed in container of water and swished to stop developing.
Then placed into Ilford Rapid fixer mixed 1:4 for 60 seconds. Had leftover from doing 35mm BW. If it was the 1:9 ratio fixer, then it needs 2 minutes. Edit: After reading this 7pg guide from Ilford at the following link, it looks like the shorter 1 minute fix using 1:4 ratio is better so that all the fixer can be removed in the washing step: http://www.film-and-darkroom-user.org.uk/forum/showthread.php?t=296
Then placed into container of water to wait till 2nd print goes through process.
Pontoon and garage print developed to a count of 420. etc.
Once both were in wash container they were placed under the running bathroom sink and rinsed for 60 minutes in slow water (The long length is due to this being Fiber paper. Resin Coated (RC) would be much shorter). The fixer needs to be thoroughly washed out.
After the 60 minutes they were placed in distilled water mixed with the Ilfotol. 500ml water and 1/4 tsp Ilfotol. The Ilfotol helps it dry evenly and quickly.
Then hung to dry.
After dried ~10 hours. These were scanned on an Epson V600 as 48bit tiffs. Then brought into Photoshop. I went to the channels view, and CTRL+ 2 or 3 or 4 to see which channel was the sharpest. Red or Green usually. Selected all, then pasted onto a new layer. Next I added a few layers: Invert layer, then a Levels Layer. Level so that the black and white just didn't clip. Lastly in Photoshop I flattened the image. Then imported into Lightroom for final edits.
Camera that took the house picture. Kodak 3A circa 1910ish.
MN Scout
That is one extraordinary piece of equipment. Not many people would know how to operate one, let alone develop the film!!
Thanks, I'm simply happy I could use my Great Grandpa's camera. It is a well engineered camera. From the googling I did, the camera was near the top of the line. They later released some with a sharper lens and a few more shutterspeed options. This would be considered the pro camera, and Kodak made a family camera that "only" took 120 film (still big compared to our normal 35mm). Back then they did a lot of contact copying, where the film was laid right onto the photo-paper and exposed. No enlarging lenses needed. This would make a big size difference for the prints that one got back from the Kodak or the local photo developer.
I see myself hopefully taking a photo that I could use for a postcard. Contact print 10 copies and send them off to my friends. That is the utility in this camera. Use it for what it was meant for. The developing is a process, but thankfully straightforward and not overly difficult, and uses the same stuff from my BW 35mm developing. Took me longer to scan, edit and airbrush out a few of the worst dust particles than the whole developing process.
Reactions: Auer
Nebell
Damn, now I want to go out and photograph macro. Been too much car photographing lately and I'm not that into cars.
And that 100 year old camera!
MN Scout
Auer I really like that curving black background. Works well!
Macro is on my list as well. I bought a reverse mount ring, so that I could mount my 28-105 zoom backwards on my camera. Initial results look promising, but haven't got it on a tripod yet.
I happened into some Eastman Safety 2 35mm film (bought a film loader and came with undisclosed film). Appears that safety film started being released to consumers in mid 1930s based on my limited reading. Since this is labeled as "2" maybe this is from the 40s or 50s? I'd sure like to know. I developed it similarly as before, but I went back down to 0.85g/500ml of KBR restrainer which is what my default for Tmax100 film is. There is a lot of base fog, so I'd like to try again at the 1.5g/500ml that I've been using on the 400 speed film. My CanoScan FS4000US scanner is using an exposure of 16, when normally it only needs 1.5 to 2. The images that I took in the range of ISO 25 to 50 look good when scanned. This was a dark overcast day, so these were shot at F/2.5 at 1/30th of a second. I've seen worse for sure. One more test with more KBR restrainer, then I can see if this film is better than the film I was going to put in the loader, or if I need to sell it off to someone else. o_O
stamsek
Marley the cat! Saw him/her on a walk w/my daughter and thought wow, beautiful cat! Next thing I know, the cat's walking over and begging for a belly rub. A neighbor explained that the cat's super friendly and belongs to someone a bit down the road.
(A73, 85mm, f1.8, 1/500, edited in Cap One and fixed up the fraying on the collar with the new Healing Tool -- really loving that feature)
I love this shot. The 85mm 1.8 really gives off some nice bokeh to isolate the subject! And it's easy to miss focus....look at those whickers!
I on the otherhand was out tonight with my wide angle:
stamsek
I'm still trying to get out and get some lightning shots, but with all the increased police activity, my wife says I should just wait until things cool off a bit. No curfew for us here, but there are some areas with curfew, so yeah, might as well just chill. What are your camera settings for this epic bolt shot?
As for the whiskers, hah, yeah, a few of them were close, but not on the mark.
We have a curfew here in AZ. 8pm-5am. I just went to a place where there were no people around.
Settings: Canon EOS 5D Mark IV • Canon EF 16-35 f/4 L IS USM @27mm • 1.6s. • f/18 • ISO 50
Had to close up the aperture and drop the ISO to get a longer exposure. Didn’t want to throw on the 10stop ND filter I had because non-night lightning is extremely difficult.
MN Scout
Auer are you developing your film, or are you sending them off? Just curious of your process. Personally I'm developing my BW, and sending my color off to Northcoastphoto.com. The color film gets pretty expensive in the end.
Auer
Usually B&W on my own and color at a local mom n pop camera shop but since covid started I have had all development done at the shop in order to give them as much support as possible.
I just drop it off in their mail box and they call me when its ready and I go to the box and pick it up.
I have access to some very high end printers and scanners but at home I just use a Epson V600 as it does MF as well and suits my personal needs for the casual stuff.
IdiotInCharge
NVIDIA SHILL
The one you posted earlier?! Wow!
Yup, we'll see how well. The CPU is a 9100F, memory is 2x8GB DDR4-3000 C15 and ancient, power supply is a 15+ year old OCZ 600W, cooler is the Intel stock whner (and the fracking arrows confuse me every five or so years when I try to use one of these again). 1TB Blue is a donor from my desktop, it normally holds Steam games. OS is Server 2016 which I believe I have a license for somewhere...
System won't run Prime95, but I'm not sure why. It will run Intel's XTU CPU w/AVX2 test for five minutes no problem as well as the memory test, so I left it with the AVX2 test set for ten hours so it'll still be running when I get home.
Main purpose for the system is to stand up a domain controller to handle internal domain stuff. I'll migrate DHCP over to it from the router, and route DNS through it (and then the piHole) before it leaves the network and so on.
bluestang
Damn people! Some amazing photos...respect :)
I need to get off my ass and got out with my aging Nikon D300 and get back in the game.
Hulk
Unfortunately Portra 160 is sold out everywhere so I had to buy a box of 5 rolls of Fujicolor PRO 400H. I'm going to rate it at 200 ISO (I heard good things about this method).
