I think my PSU is Dying. Help me Confirm?
Discussion in 'Power Supplies' started by Zarathustra[H], Feb 19, 2019.
  1. primetime
    primetime [H]ardness Supreme
    5,483
    Aug 17, 2005
    oh and my advice is do a quick temporary hookup to verify the dam thing works like Kyle does with new builds...would suck to run all those cables if it has issues lol
  2. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    27,415
    Oct 29, 2000
    Yeah, I had a pretty good feeling about it going in though. The fact that it ran perfectly OK basic on the desktop, but insta-shut down when it got a heavy load gave me a good feeling it was going to work.
  3. Zarathustra[H]
    27,415
    Oct 29, 2000
    I almost wonder if I should mention anything to MicroCenter about how their EPS extension cable...
    I'm not looking for anything from them, but it might prevent this from happening to anyone else...
  4. Paul_Johnson
    Paul_Johnson [H] PSU Editor & Admin Staff Member
    15,431
    Aug 29, 2004
    What are you going to tell them?
  5. Zarathustra[H]
    27,415
    Oct 29, 2000
    I don't know.. Maybe suggest they replace it in their stores with an extension with lower gauge wires?
    In my case things worked out OK, but I'm a pretty seasoned builder, and if I didn't think to check the gauge of the extension, I'm betting almost no one does.
    Last thing they want is someone burning down their house due to a cheap extension cable they bought at MicroCenter...
    Heck, I don't even know if they sell the one I bought there anymore.
  6. Zarathustra[H]
    27,415
    Oct 29, 2000
    Alright, strike that. I misremembered. Looks like I ordered this one on Amazon. I'm going to leave a review. Turns out I'm not the only person to have an issue with this cable.
  7. Deadjasper
    Deadjasper [H]ard|Gawd
    1,587
    Oct 28, 2001
    I'm surprised a cable can fry like that without some collateral damage occurring.
  8. GeneO
    GeneO Limp Gawd
    234
    Mar 1, 2012
    My guess is it was the cheap connector on the extension cable in this case. Resistance in the connector heated it up eventually causing the connector to fail and short-out, resulting in a large current flowing through the wire and melting the insulation. Extensions on such high current cables should be avoided.
  9. Brian_B
    Brian_B 2[H]4U
    2,261
    Mar 23, 2012
    Connectors like that usually fry because of a bad pin crimp in the connector. The heat just travels up the wire because metal conducts heat pretty well. Larger gauge wire (smaller number) would help, but doesn’t make up for shitty QC or cheap lowest bidder automated construction process — the connector would still melt out, the insulation burns up as the heat travels, then you get wire to wire or wire to ground shorts and that’s when things get interesting.
  10. Furious_Styles
    Furious_Styles [H]ard|Gawd
    1,070
    Jan 16, 2013
    So that old silverstone PSU is still good?
  11. Zarathustra[H]
    27,415
    Oct 29, 2000
    Possibly, but I don't know how to test it to make sure and I'm not chancing it.
