i think i hit the bottom for air cooling
wilson502
Its been a month since ive had my zalman cnps7000-cu, and i used as5. My temps have not changed hardly at all. my case temp varies from 21-22C and my room varies from 19-20C. idle is bout 30C sometimes dips to 28-29C, and load is about 35-38C.
I guess those temps are not overclock ?
I also get 30c idle but I get 52c load.
2.4C @ 3.6ghz
AS3, SLK-800 with ADDA 80mm 50cfm
I get 29C idle OCed to 2.3ghz.. 31 when upping the Vcore to 1.8 and OCing my gpu and 2.4ghz.. I love my cooling..
enjoy. mine's between 40-50 *c even when not overclocking... but seems to stay the same WHEN overclocking... odd...
Good temps. :)
wish my case temp was 21C... my 1700+@2200+ hits 43 C under full load (my case temp is 37C) - and this is with 2 fans and lapped stock HSF. With the side panel off CPU temp goes as high as 37-38C... darn, I gotta work on case cooling...
I have my 1700+ at 140 x 15, 2.1ghz (KT133A doesn't give very nice FSB :() at 1.725v with a big ol' Zalman Al-Cu and Nanotherm XTC at 41C full load, 37C idle. At a recent LAN party with cold cement floors I was at 34C full load :).
TheMostWantedPolishedTwin, how is ur case 37C, it must be really hot in ur room. How warm is it outside, hell my case in the summer didnt even get that hot, and it was pretty hot in this room.
