clayton006
- Jan 4, 2005
I run 1/2 ID tubing to all parts of my Loop. My loop order is as follows:
Res -> Dual pump top RAD 1 -> Heatkiller XL Mutli Block (4 GPUs) -> RAD 2 -> CPU -> Res
I'm adding a motherboard chipset block and a vreg block. The chipset block is the problem. The tubing just barely fits between two titans. I would like to go with something smaller for the chipset blocks so I can use quick disconnects so that I can easily get the motherboard out. I won't be able to go with quick disconnects if I stick with 1/2 ID.
Since I'm running two pumps I think I'll be able to overcome the restriction problem. Thoughts? I cannot return the chipset block.
