Justintoxicated
- Apr 10, 2002
I run a file server that runs 24-7 at home and one of my fractal fans finally died.
I need a replacement and want something that will function well in a horizontal orientation (I think sleeve bearings may not be the best for this but at the time they were cheap and fit the bill).
I was looking at these two fans but I'm reading the mag lev fans might not operate correctly at 7 volts)
I don't care about PWM as these will be voltage controlled.
https://www.amazon.com/Corsair-Prem...id=1485151955&sr=8-14&keywords=140mm+fan&th=1
or maybe this?
https://www.amazon.com/Premium-Qual...UTF8&qid=1485149483&sr=8-9&keywords=140mm+fan
I want quiet so maybe neither of these fans are good? It's just a fileserver although it does run some cameras. It has a 560 thin low airflow radiator to cool the CPU. I don't monitor temps closely but its been working with these weak 1000 rpm fans at 7 volt for a few years so it probably does not get very hot with the watercooling.
Quiet is important but they are for a radiator not case fans.
Thanks in advance!
or maybe this?
Thanks in advance!
