I have a APE or FLAC file that is 1 min. over the regular 700MB capacity. I use Nero 10 to overburn and the Nero totally fails. I then use Ashampoo 9 to burn, and it simply says exceed capacity. I then try ImgBurn and it asking for some ?? modules. I then try an old 2003 software call Feurio and I can't figure out how to burn or over burn Can anyone helps?
I use an old version of nero v7 I think... I have over burnt many disks.. The program itself does not integerate withanything as it is so old. But it seems to work stand alone and burns stuff. The over burn does not always work, but I think that was because I was trying for 5 mins.. A min or max 2 would be fine.. I use it with on the lap top which runs XP.. I used to burn dreamcast disks which was multi tracks with audio and data on the same disk and stuff and I have to use XP for those.
Question. Could you use an audio editing program to speed up (thus incrementally shorten), the audio file? Also, are you just burning the file to disk? Or are you trying to master an audio CD?
Have been using Clone CD for over a decade. It dows a great job overburnig and they just had an update to make it Win 10 compatible.
the main problem w/ nero is that it cut off the songs at the wrong spots. So say song 2 starts at 0:00, but it's actually playing the last few seconds of song 1. I try it on 3 disc, same thing. But using Ashampoo, the same FLAC file does NOT have that problem
Remember each track takes up a few minutes of disk space.. Making all the separate tracks into one single track, you could fit like 10 mins more onto the disk. Padus I think allowed you to use shorter gaps between tracks allowing you to fit more but it was a long time ago so I dont remember exactly. I do know tracks and sessions take up huge amount of disk space.. You would have to get rid of the cue to do it, You could just use mkv merge to append it to the first track to add it into a single file and then use mkv extract to read it back as a single file. But I never worked with flac itself so dont know.. OR you could just merge 2 of the tracks into a single file to get it to fit.
I've not burned music to a CD in a very very long time, and on top of that I haven't needed to overburn in an even longer time. That being said, there are a few things I recall that you'll both need and want to do when setting it up... [OPTIONAL] First suggestion is to waste a disc (or 2, or 3) by performing an Overburn Test (Nero CD-Speed used to), this will determine the maximum overburn possible on the brand of media you're writing to. Should you not want to do that, there ARE sites that have compiled lists of brands and media types which indicate what a typical user has been able to achieve in overburning (keep in mind that the type of drive used can also play a large part). - First you'll need to write with Disc-at-Once mode, this makes sure to close the session on the write. - Next you'll want to select whatever option your software has to "Generate a short lead-out", which itself can save 10-12MB on it's own w/o overburn. - Most importantly, you'll want to write at the lowest possible burn speed your drive can write at! Unfortunately this will increase the write time, which can be rather annoying if you're like me and choose to leave the system completely alone until it is finished in an effort to not cause any tiny hiccup that'll end up generating a shiny new coaster. It's been easily a decade since I've overburned a CD, or even DVD for that matter, but I think the most I've ever managed to cram onto a standard 80min was like 84 or 85minutes. As for Data, same guidelines apply, but I can't quite remember what I've gotten away with on that. I want to say like 770MB. You might have more luck with a continuous rip (single file) as apposed to multiple tracks. Again, just remember that LOW BURN SPEED CAN MAKE ALL THE DIFFERENCE! Not saying that drives aren't better or media has advanced a tiny bit, but you will still no doubt have more luck with 2x/4x/(maybe)8x vs 24x/28x/32x. Good luck, hope that helps even a little! [EDIT: For the record, I've always used Nero. Never been a fan of much else, but Alcohol120% is my next choice; however, no overburn experience using it.]
Wow, audio CD's. The last time I overburned was in the Nero 5-6 days, but here are some links to how-to's Nero / Feurio / Juggler etc apps. Remember this is not a red book standard as as such some blank CDR's are NOT capable of overburn without a firmware mod in some drives. YMMV! http://www.infocellar.com/CD/overburn.htm http://www.cdmediaworld.com/hardware/cdrom/cd_oversize.shtml http://www.tomshardware.com/reviews/overburning,450.html
I just download and try it. It doesn't have any option to read a CUE or FLAC file and burn it to a CD-R or does it?
okay, I just try your trick. It do the over burn, but Nero doesn't cut the song properly. So like I said earlier, song 2 beginning = end of song 1. See, when I use Ashampoo to burn the same size disk, it can burn with ea. song clearly cutting at the end of each song. But Ashampoo doesn't seem to allow overburn. So I'm force to use Nero, and Nero can overburn, but it can't burn a FLAC file w/ proper separation between songs If the CD is say 40 min, then Nero CAN properly separate the songs. With this near 80 min. CD w/ 20 songs, Nero can't do. What I need is to get Ashampoo or equivalent that can separate a FLAC or APE file properly, so each song starts at the proper spot but Ashampoo (ver. 15 latest) still does not support overburn. So I need another software that can read a APE or FLAC file properly and also support overburn
Update: JUst try Alcohol 120%, it can read APe and support overburn, but once I start the process, it says "Error Message: 05/260/00 invalid field in parameter list" now, I did notice on track 20, it's say 0000 bytes on it, is there a way for me to edit the CUE file to remove track 20? Is it a matter of just text edit out track 20, or is there more to it?
########################### System Information ########################### Windows 7 Professional x64 Edition 6.1 Service Pack 1 (Build 7601) Processor info: Intel(R) Xeon(R) CPU E5-2609 0 @ 2.40GHz x 8 (2408MHz) Physical memory available to Windows: 16,724,636 KB ############################ Program Information ########################### File Name: C:\Program Files (x86)\Alcohol Soft\Alcohol 120\Alcohol.exe Company Name: Alcohol Soft Development Team Description: Alcohol 120% Original: Alcohol.exe Product: Alcohol 120% Trademarks: Alcohol Soft Development Team Copyright: Copyright(C) 2002-2015 Alcohol Soft Development Team Version: 2.0.3 (Build 7520) Date: 3/23/2015 9:20:38 AM Size: 1639376 Bytes Hash: 7d3f6ff821c2556823524586e2a53618 File Name: C:\Program Files (x86)\Alcohol Soft\Alcohol 120\alcoholx.dll Company Name: Alcohol Soft Development Team Description: Alcohol virtual device control library Original: alcoholx.dll Product: Alcohol Copyright: Copyright (C) 2000-2014 Version: 4.45.0 (Build 0) Date: 1/3/2015 11:27:38 AM Size: 862512 Bytes Hash: 4b26fe4d7146ddf44e787623eb50bc61 File Name: C:\Program Files (x86)\Alcohol Soft\Alcohol 120\DevSupp.dll Company Name: Alcohol Soft Development Team Description: Alcohol Software Device Capability Library Original: DevSupp.dll Product: Alcohol Software Device Capability Library Copyright: Copyright(C) 2002-2015 Alcohol Soft Development Team Version: 2.8.1 (Build 8007) Date: 3/7/2015 5:41:20 PM Size: 59120 Bytes Hash: 6c690043f473d3117c2e805d1fc4c72c ########################### User Information ########################### Licensed to: UN-REGISTERED ( 8/23/2015 ) Registered User ID: UN-REGISTERED ########################### Options Setting ########################### Devices Control Interface: Default Device Control Interface (recommended) [SPTDIntf] SCSI Pass Through Direct (SPTD) layer version: 1.87 CPU Priority Level: High Memory Buffer Size (MB): 1024 Examine the accuracy of data read from physical device: Yes Enable Enhanced Weak Sector Scanner during dumping: No Overburn disc(s): No Turn off "Auto-Select best write speed" function if possible: No Fill memory buffer before recording discs: Yes Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No Ignore Media Type: No RMPS (Recordable Media Physical Signature) Emulation: No BAD Sectors Emulation: No Sub-Channel Data Fixed & Emulation: No Laserlock Emulation: No UI Language: English ############################ Device(s) List ############################ (G PIONEER BD-RW BDR-207M (atapi, Port 12, Bus 4, Target 0, Lun 0) ##################### Installed Device Drivers List ##################### 1394ohci.sys a18u9o2y.SYS ACPI.sys adfs.SYS advapi32.dll afd.sys AgileVpn.sys amdxata.sys api-ms-win-downlevel-advapi32-l1-1-0.dll api-ms-win-downlevel-normaliz-l1-1-0.dll api-ms-win-downlevel-ole32-l1-1-0.dll api-ms-win-downlevel-shlwapi-l1-1-0.dll api-ms-win-downlevel-user32-l1-1-0.dll api-ms-win-downlevel-version-l1-1-0.dll apisetschema.dll asmthub3.sys asmtxhci.sys asyncmac.sys atapi.sys ataport.SYS ATMFD.DLL autochk.exe Beep.SYS blbdrive.sys bowser.sys cdd.dll cdfs.sys cdrom.sys cfgmgr32.dll CI.dll CLASSPNP.SYS clbcatq.dll CLFS.SYS cng.sys comctl32.dll comdlg32.dll CompositeBus.sys crashdmp.sys crypt32.dll csc.sys cthda.sys cthdb.sys devobj.dll dfsc.sys difxapi.dll discache.sys disk.sys drmk.sys dump_dumpata.sys dump_dumpfve.sys dump_msahci.sys Dxapi.sys dxgkrnl.sys dxgmms1.sys e1q62x64.sys ElbyCDFL.sys ElbyCDIO.sys fileinfo.sys fltmgr.sys Fs_Rec.sys fvevol.sys fwpkclnt.sys gdi32.dll hal.dll HDAudBus.sys HdAudio.sys HIDCLASS.SYS HIDPARSE.SYS hidusb.sys HTTP.sys hwpolicy.sys iaStorF.sys iaStorS.sys iertutil.dll imagehlp.dll imm32.dll intelppm.sys kbdclass.sys kbdhid.sys kdcom.dll kernel32.dll KernelBase.dll ks.sys ksecdd.sys ksecpkg.sys ksthunk.sys lltdio.sys lpk.dll luafv.sys mcupdate_GenuineIntel.dll monitor.sys mouclass.sys mouhid.sys mountmgr.sys MpFilter.sys mpsdrv.sys mrxsmb.sys mrxsmb10.sys mrxsmb20.sys msahci.sys msasn1.dll msctf.dll Msfs.SYS msisadrv.sys msrpc.sys mssmbios.sys msvcrt.dll mup.sys mv91cons.sys ndis.sys ndistapi.sys ndiswan.sys NDProxy.SYS netbios.sys netbt.sys NETIO.SYS NisDrvWFP.sys normaliz.dll normaliz.dll Npfs.SYS nsi.dll nsiproxy.sys ntdll.dll Ntfs.sys ntoskrnl.exe Null.SYS nvlddmkm.sys ole32.dll oleaut32.dll pacer.sys partmgr.sys pci.sys PCIIDEX.SYS pcw.sys peauth.sys portcls.sys psapi.dll PSHED.dll PxHlpa64.sys rasl2tp.sys raspppoe.sys raspptp.sys rassstp.sys rdbss.sys rdpbus.sys RDPCDD.sys rdpencdd.sys rdprefmp.sys rdyboost.sys rpcrt4.dll rspndr.sys RTKVHD64.sys SaiBus.sys SaiMini.sys SCSIPORT.SYS secdrv.SYS sechost.dll serenum.sys serial.sys serscan.sys setupapi.dll shell32.dll shlwapi.dll smss.exe spldr.sys sptd.sys spvdbus.sys spvve.sys srv.sys srv2.sys srvnet.sys storport.sys swenum.sys tcpip.sys tcpipreg.sys TDI.SYS tdx.sys termdd.sys TSDDD.dll tunnel.sys umbus.sys urlmon.dll usbccgp.sys USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS USBSTOR.SYS user32.dll usp10.dll vdrvroot.sys vga.sys VIDEOPRT.SYS vmstorfl.sys volmgr.sys volmgrx.sys volsnap.sys wanarp.sys watchdog.sys Wdf01000.sys WDFLDR.SYS wfplwf.sys win32k.sys wininet.dll wintrust.dll Wldap32.dll wmiacpi.sys WMILIB.SYS ws2_32.dll WudfPf.sys WUDFRd.sys ################## Detailed Information of Device(s) ################## /////////////////////////////////////////////////////////////////////// (G PIONEER BD-RW BDR-207M (12:0) detail information. /////////////////////////////////////////////////////////////////////// Vendor Identification: PIONEER Product Identification: BD-RW BDR-207M Production Revision Level: 1.21 Location: atapi, Port 12, Bus 4, Target 0, Lun 0 Support recording method: DAO / SAO, RAW SAO, RAW SAO + SUB, RAW DAO(96), TAO, DVD DAO, BD DAO BURN-Free Technology: Supported ( Unknown ) Auto-Select best write speed: Not Supported *** Drive NOT listed in our drive database. Contact Alcohol support team to rectify this. * [CD] -ROM R/W: V/X, -R R/W: V/V, -RW R/W: V/V * [DVD] -ROM R/W: V/X, -R R/W: V/V, -RW R/W: V/V, +R R/W: V/V, +RW R/W: V/V, -RAM R/W: V/V * [HD DVD] -ROM R/W: X/X, -R R/W: X/X, -RW R/W: X/X, -RAM R/W: X/X * [BD] -ROM R/W: V/X, -R R/W: V/V, -RE R/W: V/V -* Note: This information below is provided by the unit, it might be inaccurate. *- -* This software does not use this information! *- Removable media: Yes Version: ATAPI (INF-8090i/INF-8020i/INF-8028i) Response Data Format: 02h CD-R & CD-RW Read / Write: CD-R: Yes / Yes, CD-RW: Yes / Yes Read CD-R Fixed Packet: Yes Test Write: Yes DVD-ROM Read: Yes DVD-R and DVD-RAM Read / Write: DVD-R: Yes / Yes, DVD-RAM: Yes / Yes Audio Play: Yes Composite Audio and Video Data Stream: No Digital output (IEC958) on port 1 / 2 Supported: No / No Mode 2 Form 1 / 2: Yes / Yes Multi-Session: Yes BUF: Yes CD-DA Commands supported: Yes CD-DA Stream is Accurate: Yes R-W Supported: No R-W De-interleaved and Corrected: No C2 Pointers Support: No ISRC / UPC Supported: Yes / Yes Read Bar Code: No Lock media into the drive: Yes Currently drive Lock state: Unlocked Prevent Jumper: No Eject Command: Yes Separate volume levels: Yes Separate channel mute: Yes Changer Supports Disc Present: No Software slot selection: No Side change capable: No P through W in Lead-In: Yes ####################################################################### ###################### Source Disc/Image Information ###################### Type: Cue-sheets Image file Path: E:\CD_3_SpecialsAndRaritiesVol3\ Name: JenniferRush_2007_Stronghold(CD_3)_SpecialsAndRarities.cue Size: 546.6 MB Session: 1 Track: 20 File(s): JenniferRush_2007_Stronghold(CD_3)_SpecialsAndRarities.ape ############################################################################# ####################### Dumping/Recording Progress Log ####################### ********* Time stamp of this log file: 8/23/2015 10:43:25 AM ********* 10:43:25 Processor info: Intel(R) Xeon(R) CPU E5-2609 0 @ 2.40GHz x 8 (2408MHz) 10:43:25 Physical memory available to Windows: 16,724,636 KB 10:43:25 Memory Buffer size: 1024 MB 10:43:25 Image file loading: E:\CD_3_SpecialsAndRaritiesVol3\JenniferRush_2007_Stronghold(CD_3)_SpecialsAndRarities.cue 10:43:25 Source Info: Session: 1, Track: 20, Length: 673.3 MB / 76:36:26 10:43:25 Image file loading completed! 10:43:25 (G PIONEER BD-RW BDR-207M (12:0): Recording Method/Speed 10:43:25 Illegal speed 4X (600 KB/Sec) for this media, running on 1X (150 KB/Sec) 10:43:25 Recording - DAO / SAO - 1X (150 KB/Sec) 10:43:28 (G PIONEER BD-RW BDR-207M (12:0): BURN-Free activated RAW Packet DAO/SAO mode failed, try to use block changing DAO/SAO mode 10:43:28 (G PIONEER BD-RW BDR-207M (12:0) - [SEND CUE SHEET ERROR] CDB: 5D 00 00 00 00 00 00 00 B8 00 00 00 D:-0--1--2--3--4--5--6--7--8--9--A--B--C--D--E--F-- 01 00 00 01 00 00 00 00 01 01 00 00 00 00 00 00 01 01 01 00 00 00 02 00 01 02 01 00 00 03 13 35 01 03 01 00 00 05 06 06 01 04 01 00 00 08 04 4A 01 05 01 00 00 0A 26 1D 01 06 01 00 00 0D 27 35 01 07 01 00 00 10 2A 14 01 08 01 00 00 14 00 15 01 09 01 00 00 17 2D 41 01 0A 01 00 00 1C 27 30 01 0B 01 00 00 21 3B 46 01 0C 01 00 00 26 04 2D 01 0D 01 00 00 2C 2E 34 01 0E 01 00 00 31 11 38 01 0F 01 00 00 35 13 2A 01 10 01 00 00 3A 25 14 01 11 01 00 00 3E 23 1A 01 12 01 00 00 42 11 03 01 13 01 00 00 47 09 27 01 14 01 00 00 4C 26 1A 01 AA 01 01 00 4C 26 1A S:KEY - 05/26/00 - "Invalid Field In Parameter List" 10:43:28 (G PIONEER BD-RW BDR-207M (12:0): Recording failed! 10:43:28 Error message: [05/26/00] - Invalid Field In Parameter List 10:43:28 (G PIONEER BD-RW BDR-207M (12:0): Recording failed! 10:43:31 Something is wrong with the recording procedure! Please check the log file and report any errors to Technical Support. ##############################################################################
I just tried Disc LUggler, it crashes during the run, so at this point, I don't know what more to do. Alcohol 120 is the best bet if I can fix that error.
CDBurnerXP might be able to do it but you can use it to create an image that ImgBurn which I know for a fact will overburn (I did it with my BenQ 1655 and DVD+R discs). Wherever there is a selection, the disc has to be burned DAO JFYI.
Not all drives support overburning and you can do about 2 minutes tops off a regular disc, there were discs however that did 90 mins officially. //Danne
I used to burn with nero, but not trust it with flac/ape. Instead I used foobar2000 to make a nero image first. I'm not sure if foobar2000 still has a nero plugin.
If you burn with nero is nto working, I doubt the image would make a difference.. best bet like some others have said it to do it at disk at once mode where it does a short gap and saves some space and depending on how many tracks there are might get it to fit. There are nero to iso and iso to nero image utilities. And the final option like I said would be to make 2 tracks into 1 so the gap is absent which would get it to fit but then you dont have the track seperation. Do not use ANY session stuff as it takes over 5 mins of space..
Update: CDBurnerXP works. It doesn't give any error and I finally successfully burn this 80 min. CD Thank you very much for your suggestion. IMgBurn doesn't work, it gives error (asking me for extra filter)
Nice! Sorry I just saw the part about ImgBurn, that is really odd. ImgBurn is my go-to for overburning but CDBurnerXP is all I ever use really. Used be Nero in the pre-v10 days.
filename: ............flac. out of interest, this is the error: connect filters failed. Reason: No combination of intermediate filters could be found to make connection Hint: You may need to install some additional direct show filters in order to support files of this type =========== APE yields the same error. Clearly it's a bug, as CDBurner XP doesn't have that error
I don't think it's a bug, ImgBurn is made to burn images, it supports ape and flac (which are not CD images) only if your OS has a directshow filter for those : ImgBurn supports a wide range of image file formats - including BIN, CCD, CDI, CUE, DI, DVD, GI, IMG, ISO, MDS, NRG and PDI. It can burn Audio CD's from any file type supported via DirectShow / ACM - including AAC, APE, FLAC, M4A, MP3, MP4, MPC, OGG, PCM, WAV, WMA and WV.
It reminds me of FDDshow, it looks like the software is missing a filter / CODEC or whatever you want to call it For a 80 min. CD, I find it hard to believe Nero ver. 10 can't burn it. CDBurnXP is many years old, whereas Nero 10 is a paid software only a few yr. old. How can a few yr. old software unable to burn a 80 min. CD? We have 80 min. Cd for at least 1+ decade the burn result from Nero is horrible. Songs becomes at the middle or at the end, and the same song repeats itself.
