I need help for dimensions between holes on miniITX motherboard and dimensions for backside
medoni
Hi there. I'm making my first mini itx pc case mod.
May someone help me?
I need dimensions for holes of components. Measuring components I've got some dimensions, but there is some deviations of it. Below are the components that I chose:
Motherboard - GIGABYTE GA-Z170N-WIFI
Graphic Card - GIGABYTE GV-N970IXOC-4GD GTX970 4GB GDDR5
Power supply unit - SHARKOON SilentStorm SFX Gold 500W
SSD - Samsung 850 EVO 250GB"
Fan - Noctua NF-A8 PWM
Thank you very much.
medoni
If you are looking for motherboard standoff hole dimensions, I found this: https://www.silverstonetek.com/techtalk_cont.php?area=usa&tid=wh11_008
Thanks a lot for the link. Unfortunately I already used similar schemes but when I cut it didn't match. I need someone who has already made itx mode (physical) and has checked all dimensions?
Required hole dimensions:
1. Motherboard:
- Dimensions for layout of standoffs for motherboard (layout of the holes where the standoffs come in)
- Dimensions on back side of computer case in place where is located i/o shield for motherboard
2. Graphics card:
- Dimensions holes of slot on the back side of computer case for position graphic card below the i/o shield of motherboard.
- Dimensions of slot for bracket of graphic card in the bottom of the computer case where the graphics card bracket enters
3. Dimensions ratio between standoffs of motherboard on bracket and cover on the right side of computer case.
Thanks
medoni
What openings do you need?
1. Motherboard:
2. Graphics card:
Thanks
