I need a cable, 1 end cigar lighter, the other end micro USB
Discussion in 'Smart Phones and Devices' started by Happy Hopping, Dec 19, 2014.
  1. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,610
    Jul 1, 2004
    to power / charge my Nokia phone.
    I bought 1 cable that is USB to micro USB from monoprice, and that cable fails in less than 1 yr. Cheap quality cable, waste $ on shipping
    Now I want 1 end as that cigar lighter w/ the other end being mirco USB, where would you go for a cable like that?
  2. FndTheRver
    FndTheRver Gawd
    626
    Nov 30, 2005
    I'd check Monoprice
  3. bman212121
    bman212121 [H]ard|Gawd
    1,533
    Aug 18, 2011
  4. UnknownSouljer
    UnknownSouljer [H]ardness Supreme
    5,956
    Sep 24, 2001
  5. Happy Hopping
    6,610
    Jul 1, 2004
    that's 2 part connector like Belkin is the one that I have. It now seems like the current USB to cigar adapter is failing. But the copper wire connects to the USB Mirco B is also loose, there is no "housing" connects to it, so it can easily come off.
    I like that one at ebay, I wonder what is the difference btwn. that one vs. the 1 w/ MOtorola, or you think it's just the brand name?
  6. Domini
    Domini 2[H]4U
    2,079
    Sep 12, 2005
    Belkin has never been known for quality, its usually the overpriced stuff people buy at retail stores. The charger on ebay looks like one i could grab from the dollar store.
  7. jimh425
    jimh425 Gawd
    644
    Jan 7, 2012
    If the cable is failing, my guess is it is too flexible. Look for a thicker one.
  8. pharmecist
    pharmecist n00b
    42
    Dec 7, 2009
  9. Happy Hopping
    6,610
    Jul 1, 2004
    Go to view the customer review of those 2 Amazon link as well as the Ebay link:
    All of them said it doesn't work or only works for a few days
    at amazon: 398 1 star review, 222 2 star review
    at ebay: 242 -ve review in 1 mth, 2653 -ve review in 12 mth
  10. Rav3n
    Rav3n Gawd
    1,013
    Jul 24, 2014
  11. Trombe
    Trombe Gawd
    891
    Jan 25, 2007
    I would spend a bit more up front and get that anker one, it's not that much more expensive in the grand scheme of things for having smart ports and high customer satisfaction and reliability.
  12. Shlunky11
    Shlunky11 n00b
    27
    Dec 13, 2014
    Yeah, Anker is tough to beat. Their customer service is top notch, and I have had very good success with their products. They are always my first go to for anything mobile related..
  13. Happy Hopping
    6,610
    Jul 1, 2004
  14. Happy Hopping
    6,610
    Jul 1, 2004
    but there are 339 -ve review on that same page
    user comment like this
  15. irv_usc
    irv_usc n00b
    16
    Mar 18, 2014
    i use the non-premium monoprice cables. there is more strain relief on the connector ends. cheaper and last longer than the premium version.
    the downside is that the connector end is larger, so if you're using a case on your phone it might not fit.
  16. ZLoth
    ZLoth Gawd
    854
    Apr 13, 2010
    USB cables are cheap, especially if you avoid the ones sold by a certain... Mobster. The biggest problem I face is that the little retainer clips at the end of the microUSB wear out after a month or so of use. Fortunately, Monoprice sells in bulk.
  17. PCunicorn
    PCunicorn [H]ard|Gawd
    1,638
    Mar 26, 2013
    Get this one OP. Amazing reviews. Don't get cheap chargers, they don't last a long time and they hurt your devices.
  18. Trimlock
    Trimlock [H]ardForum Junkie
    15,157
    Sep 23, 2005
    I have 3 Anker chargers and am still using them all (2 wall mounts and the one linked above).
    It works very well.
  19. Happy Hopping
    6,610
    Jul 1, 2004
    scroll up. 339 -ve review on that same link you quoted
