I microwaved a R9 390X gaming and now my pc won't run after 3rd time
princeboy47
Hello guys. Sorry for the delay...
Good news, the whole thing here, and the PC, is completely good. The only problem they found is a small scratch on the mobo I/O chip that caused two pins to be touched. Yup, I think you would say oops. So nothing was damaged.
Furthermore, the graphics card is still being checked. It's not running.
However, the graphics card is missing two connectors. The plastic pins covering is simply not on the card at all. And it is missing the RGB side light plug head, cut. Other than that, microwave, I remember, had heated around the edges of the metal graphics card pins on the pcb, the 6 and 8-pin connectors I mean. And also around the interface sockets. And I remember something had melted on the microwave Glass tray from the graphics card, which led to breaking it recently due to having it heated several times while on the microwave tray. I am not sure if the molten thread is metal or not so it has caused something like that. However, I think I will wait for sometime until I get a call back..
So no worries here...
Nobu
Woo! Dodged a bullet on the MB. I'd have still parted it out and sold or kept as a backup. Call me skeptical. lol
Hakaba
1 Microwaved graphics card for few minutes, because it has the overheating issues.
2 Plastic around pins were melted and some plugs around interface sockets, the metal part, had some burning coming out.
3 Removed the graphics card, installed it, failed to show anything on the display at all.
4 3rd time PC won't even turn on as in power. The ethernet LED was lit.
4 Tried that again with unplugging cables and having one RAM only in the PC and only the main SSD
5 Now the PC won't turn on at all, ethernet LED is not turning on.
6 tried couple of tricks from the internet to turn it on like have a screw driver on both power switch pins but nothing happens.
7 HELP !!!
I really hope you used a microwave that is 3000W or higher. If not, what most likely happened is that the longer cook time caused the turbo encabulator magnetic seals to weaken, which led blue smoke escaping the vacuum sealed chambers. When this happens you generally have to desolder the GPU die (since it is located directly under it) and replace it with one from the same generation. I would recommend a Dyson hairdryer, it is cheaper than a hot air station but not as effective. However, it will get the job done, and make sure you get the three prong version, it is able to dissipate ESD. Unlike its two prong counterpart.
Reassembly is pretty straight forward. The only difficult part with be re-balling the GPU die. Now they make templates for some dies, which allows you to drop the lead based solder balls into the correct position. However, if you re unlucky and have to design your own, you can use a 3D printer or a 3D printing pen (a lot cheaper, but harder to deal with). After that, if you have a hot air station you can just heat it up till everything flows and seats and your done! The other way is to use a Coleman induction heater, small iron pipe (to transfer the heat to the die). But you cannot crank it to max without breaking something. So, use some painters tape to hold it down (doesn’t leave any residue behind), flip it upside down and balance it on the iron pipe, set it to mediums. Set the dyson blower to low, and just sweep back and forth on the reverse side of the socket.
That is only for the GPU die itself, since I never replaced a turbo encabulator before, it’s best to Google it and see how others have done it. I would hate for you to follow only my steps and break something.
Good Luck!
criccio
Fully Equipped
Good Luck!
You sir are a national treasure.
mlcarson
I guess we all have an idea what another Carrington Event would do to our graphic cards now...
cpufrost
200kA is a LOT of current. That switch took a serious beating.
That rig would be fun to simulate lightning strikes on hardware.
The magnetic field from those pulses could do serious damage too.
Imagine that in the hands of TechRax! :-D
ChadD
How did I miss this thread. Great entertainment. If that was a troll it was fun... if serious also fun and I'm glad the OP was still alive to keep posting.
I admit years back I baked a ATI graphics card... got me another 6 months out of it and when it died I hit it with a somewhat more proper heat gun and got another few months out of it. (and I have to assume at this point traces have got so small that baking a card would be a terrible idea likely to fry your mother board as well)
This had to be a troll though... I mean who doesn't understand at least generally how a microwave works. lol
ZodaEX
I don't understand why he hasn't been banned for trolling yet.
ChRoNo16
Microwaved Computer
Watch that video, thats what you did to your computer, just buy a new one and learn the lesson. toaster oven or conventional over or hair dryer, those are feasable ways to reflow a card or motherboard. what you did was murder.
Gavian
Metal in microwave = high-voltage arcs. High-voltage arcs + computer parts = kaputsky. Utterly destroyed graphics card installed in motherboard = shorted out motherboard.
For some reason I read this with a Mordin Solus voice 😅
silent-circuit
Okay, video is not important. PS is working good now, with a paperclip.
If powering the PC all together it doesn't turn on.
Turning the case with a screwdriver bridging the power switch doesn't work.
That happens with or without the graphics card connected.
Also, is it possible to turn the PC on without the cpu 4 pins connected?
pendragon1
Extremely [H]
wat?!
Shoganai
I have no idea what you're talking about. Whatever you're doing, just stop.
