I just made 25 bucks in burst!
Discussion in 'Mining & Cryptocurrency' started by Hitti2, Jun 14, 2017.
  1. odditory
    odditory [H]ardness Supreme
    4,110
    Dec 23, 2007
    ^ No point mining Sia coins if holding them in hopes they increase value is the goal: they aren't intended to store value, they're unlimited supply, and they're going ASIC next year.
  2. DuronClocker
    DuronClocker [H]ard|Gawd
    1,070
    Mar 12, 2004
    This is pretty ridiculous.
  3. Lunas
    Lunas [H]ardForum Junkie
    9,503
    Jul 22, 2001
    yep supposedly burst nation and crowetic and nameless are behind it namless lost some 6 digits of fiat currency in a ponzi scheme that failed rumor is they are crashing burst to recoup the money they lost supposedly they will need it to drop below 300 then they will pump and dump the coin...
  4. 6foot4geek
    6foot4geek [H]ard|Gawd
    1,254
    Apr 27, 2008
    So much effin drama geeeezzz...
  5. Lunas
    9,503
    Jul 22, 2001
    good news is the coin did not quite drop that low and seems to be stabilized
  6. ryan_975
    ryan_975 [H]ardForum Junkie
    13,840
    Feb 6, 2006
    How does that work?
  7. mkrohn
    mkrohn [H]ard|Gawd
    1,758
    Apr 30, 2012
    Well if enough people abandon it the value tanks. Then they buy up and stop the attack and promote it being the best thing in the world just to dump it and value tanks again.
  8. ryan_975
    13,840
    Feb 6, 2006
    ahh okay that makes sense.. I was looking at it as if they had already bought it or sold it, and couldn't figure out how tanking the value would help them.
  9. EvilWays
    EvilWays [H]ard|Gawd
    1,489
    Apr 9, 2006
    Lex? The one that was defending crowe and nameless? No thanks.
  10. EvilWays
    1,489
    Apr 9, 2006
    Crowe and nameless, yes. BN, no (unless there is something the whole community is missing besides all the shittalking).
  11. Lunas
    9,503
    Jul 22, 2001
    alot are saying bn servers are involved so much so they are being banned by one side particularly the side that lexi and btfg and lilfiend is using.
    bn is trying to put forward the blockchain crowetic and co supposedly are backing
  12. lilfiend
    lilfiend [H]ardness Supreme
    6,494
    Nov 28, 2008
    Well consider me ill informed.
    If there is a preferred chain for me to go on all I need to know is the ip address of a wallet on it to set it as a trusted peer.
    I have a blockchain download available on burstfiend.com/db.tgz, it starts at block 384319, i'm not sure on what block the forking started so if its too recent I can replace with one around block 370000.
  13. Lunas
    9,503
    Jul 22, 2001
    # Known bad peers to be blacklisted
    nxt.knownBlacklistedPeers=cybaer.dyndns.org; wallet.burstcoin.tech; burstcoin.shmtech.biz:9682; wallet3.burstnation.com; wallet1.burstnation.com; wallet2.burstnation.com; network.burstnation.com; pool.burstmining.club; wallet5.burstnation.com; bwallet.burstmining.club; burst.cybaer.dyndns.org; cwallet.burstmining.club; wallet4.burstnation.com; awallet.burstmining.club;
    # A list of well known peer addresses / host names, separated by '; '.
    # If not set, a random selection of nxtcrypto.org and nxtbase.com nodes is used.
    nxt.wellKnownPeers=73.114.181.127; 84.112.70.104; 45.58.62.236; 176.9.25.254; 5.104.175.157; 195.230.182.182; 71.166.55.129; 5.104.175.152; 5.104.175.136; 5.104.175.138; 137.248.121.73; 94.23.249.104; [2a01:4f8:140:8168:0:0:0:109]; 213.113.246.35; 86.124.110.199; 89.40.228.171; 5.104.175.11; [2001:44b8:41b2:2f00:6a05:caff:fe0b:fdf6]; 88.99.166.52; 5.104.175.131; 62.224.96.21; 109.190.100.208; 172.89.42.79; 70.89.173.103; 93.123.73.133; [2a07:5741:0:b12:0:0:0:1]; 35.187.68.75; 46.237.194.160; 5.104.175.214; 5.104.175.217; 5.104.175.218; 80.122.157.25; 39.117.137.191; 68.146.112.21; 185.157.21.85; 198.100.144.47; 192.99.183.10; 88.222.9.72; [2a01:e35:8bfa:cf90:cd05:c3bb:beb3:57a0]; [2604:6400:401e:1300:d0ed:542c:9f2e:5b99]; 37.97.40.203; 70.180.246.148; 87.167.177.45; 144.76.90.228; 75.158.125.140; [2002:ad13:7003:e472:35c9:53d0:b5b3:3d2a]; [2001:0:9d38:953c:1c87:1460:b94d:65ac]; 70.95.197.163; [2a01:e35:8bfa:cf90:fce2:9368:cdd7:e010]; 126.124.211.226; 92.43.104.34; 125.142.247.137; 162.236.93.205; 91.143.92.133; 111.242.140.82; [2400:4800:401a:24:f5ad:adf7:e076:5827]; 171.233.128.63; 140.113.215.141; 95.88.125.245; 85.217.171.59; 184.161.232.180; 188.2.144.168; 87.98.244.116; [2002:ad13:7003:e472:b509:7267:aa17:2878]; 104.155.2.114; 121.99.231.47; 216.165.179.49; 93.88.74.26; 185.144.131.131; 94.232.119.7; 130.236.232.24; 108.238.244.144;
    the two above go in nxt-default properties
    as for how i know you're on the right chain the block you are on
    384629 is the current one of the active fork
  14. lilfiend
    6,494
    Nov 28, 2008
    ^ done with an older rollback and no other peers allowed until it can sync up and i can back up the db for that fork.
  15. Lunas
    9,503
    Jul 22, 2001
    the strongest chain is on 384676 now.
  16. EvilWays
    1,489
    Apr 9, 2006
    daWallet has released 1.2.9-rc2 of the standalone local wallet (available here) - download the burst.jar and either of the other files, then unpack and copy/move the jar file in to the new directory and run. You will have to start with a new blockchain database. One change to the config is that it is now set up for needing 10 wellknownpeers instead of 2 for 1.2.8 and prior.
    The pools keep attempting to reach a consensus but also keep forking over and over. The network monitor also keeps going back and forth on the Last block with same GenerationSignature, between 384234 and 384303, which could make determining where to hard fork (if necessary) difficult.
    If someone, or some group, were to make another PoC based coin, perhaps they'll look at IOTA and the DAG based transaction ledger system (Tangle), which doesn't require sequential processing of transactions unlike almost every other crypto out there. This would help mitigate the damage done by the message spam attack that happened with burst. Another option would be to copy the "Gas" mechanism from Etherium for mitigating spam attacks.
  17. pclausen
    pclausen Limp Gawd
    218
    Jan 30, 2008
  18. Lunas
    9,503
    Jul 22, 2001
  19. EvilWays
    1,489
    Apr 9, 2006
  20. Lunas
    9,503
    Jul 22, 2001
  21. 6foot4geek
    1,254
    Apr 27, 2008
    Well shit... https://steemit.com/cryptocurrency/@iceburst/the-death-of-burst-coin-the-final-nail
    Not to add to the drama but it does look like Bittrex and Poloniex disabled burst. It makes sense to protect buyers and sellers on the various forks but if they don't reactivate it there's not outlet for the currency. If / when we pull out of this I'm sure it'll rally just fine.
    And for those not aware: https://hardforum.com/threads/180-8tb-wd-external-easystore-usb3-8tb-wd-red-inside.1930595/
    $160 - 8TB usb3 drives, I run several of these exact drives for burstcoin mining.
  22. Zepher
    Zepher [H]ipster Replacement
    15,127
    Sep 29, 2001
    That is a good deal on that drive, my dad just bought one for me as an early birthday gift, going to pick it up shortly.
  23. pclausen
    pclausen Limp Gawd
    218
    Jan 30, 2008
    I snagged 4 yesterday. That takes me to 256TB on this burst box.
    Btw, 1.2.8mu is out now and the recommendation is that we all switch to that version. It went smoothly for me and I have been current for the last several hours now. Right now i'm on:
    385231 7/24/2017 16:40:52 0 + 0 0
    Peter
  24. Zepher
    15,127
    Sep 29, 2001
    there are 2 models of this drive,
    WD80EFAX and WD80EFZX. The AX model is made in Thailand and has 256mb Cache, the other is made in China and has 128mb cache.
    I happened to get the WD80EFAX model with 256mb cache.
  25. pclausen
    pclausen Limp Gawd
    218
    Jan 30, 2008
    And there are also the WD80EZZX. Got 4 of those as well. Those are in the MyBook enclosures with the square nose vs. the rounded nose.
    [​IMG]
  26. odditory
    4,110
    Dec 23, 2007
    You guys are still buying more drives for Burst mining eh?
  27. pclausen
    pclausen Limp Gawd
    218
    Jan 30, 2008
    That and 1080Ti cards. :)
    JRUHg likes this.
  28. Zepher
    15,127
    Sep 29, 2001
    Naw, I got mine for porn storage as my 3TB is full.
  29. odditory
    4,110
    Dec 23, 2007
    If Bittrex and Polo don't reactivate Burst, it doesn't exist.
  30. EvilWays
    1,489
    Apr 9, 2006
    1.2.9b-rc2 has been working for me so far.
    Looks like there is a 1.2.9c version out, but looks like it has some untested stuff in it yet. I'll wait before switching versions again either way.
    At least the network is starting to get its act together. Just have to wait it out a bit longer.
  31. Lunas
    9,503
    Jul 22, 2001
    problem is that cant be mined on or used to send burst only see your burst... i have made 300 during shit storm bust so far and .009 btc off the burst going low buying a crapload then selling while it was being pumped up till they closed withdrawals and deposits i just wish all my burst had been on polo at the time...
    I am going to stick with it a while longer I am hoping either a new poc coin is created or this mess gets fixed. I liked this while it worked. The attackers account still has burst left 260k last I saw and each of his spams cost him 1. The bodge fix prevents the attack but does not exactly fix the issue that is being exploited... It was quickly pushed through and that is what got us back to this point. But the account is still attacking...
    I honestly hope the perp turns out to be not one of the dev team. If it is pajeet and it is for the reason I think it was I hope they string him up...
    Pajeet is the operator of a presumed illegal botnet of 15k+ bots each with at least 200GB of plots he was using to mine with. According to detective work done he was a student or employee at a university. And people upset by his exploiting of burst got his info and may have exposed him to the school or his bosses.
    UPDATE:
    New wallet https://github.com/dawallet/burstwindowswallet/releases/
    built in ddos protection fixes for the exploit.
    Drama coming off of Burst nation still stinking up the room...
    Adam G. former dev and current neo nazi dbag has made physical and economical threats towards one of the few devs who actually worked to solve the problem Lexicon
    Adam G. despite doing nothing positive for the coin has claimed he single handedly saved the coin and continues to bad mouth the people who actually worked hard to save burst...
    He remains under suspicion of being behind the attack and he has no ground to stand in his defence as his Burstnation has done similar attacks but at a smaller scale in the past....
    Devs and pool owners responsible for actually working to fix the problem.
    Lexicon, Valareous (BTFG admin), DaWallet, MSFT, Haitch (admin Burst-team.us), and many other burst pool operators who worked hard protecting the servers and updating to code as it was sanitized.
  32. TordanGow
    TordanGow Limp Gawd
    133
    May 25, 2015
    I bought 5 of those refurb 3TB Hitachi 641s for $42 each. If burst dies I'll just make a NAS. I've been wanting to do that anyways.
  33. pclausen
    pclausen Limp Gawd
    218
    Jan 30, 2008
    Appreciate the update Lunas. I have pretty much reached the same conclusion after spending some time on both BN and Burst-team.us (which was down for quite a while during the first few days of the attach). Hopefully this silly feud will end at some point. It does burst absolutely no good. We'll see if it is too late already or not.
  34. DuronClocker
    1,070
    Mar 12, 2004
    Anyone still doing this? I've had just over 100TB up and running now for a little while. I'm up to around 8500 burst.
  35. Zepher
    15,127
    Sep 29, 2001
    Mine is still running, have 3354 with my initial 12TB still.
  36. NmCRooK
    NmCRooK Limp Gawd
    389
    Jul 21, 2009
    Too inconsistent for me. I'll keep mining until I hit 10k (5300) now after 3 weeks of downtime.. after that if a pool/wallet is stable, I'll keep going.
    Can someone please direct me to the most recent DB so I don't have to download the block chain all over again???
  37. Lunas
    9,503
    Jul 22, 2001
    Price is dropping pretty steady. I'm still mining with my 17tb. Still on bftg as it was one of a few who did not die while the attack was in full swing.
    https://burstwallet.io/burstcoin-blockchain-download/
    i think it ended up 2-3 days i could not mine but 1 week of worthless mining...
    NmCRooK likes this.
  38. pclausen
    pclausen Limp Gawd
    218
    Jan 30, 2008
    Things have been running pretty stable for me solo mining. Just under 20k burst now and I'm still in the middle of re-plotting (after changing from small RAID0 arrays behind an Areca controller, to individually mapped volumes behind LSI HBA). I'm now able to read/scan ~250TB in about 30 seconds.
    This looks promising:
    https://bitcointalk.org/index.php?topic=2080040.0
  39. Gilthanis
    Gilthanis [H]ard|DCer of the Year - 2014
    6,102
    Jan 29, 2006
    I'm just now getting enough spare time to plot my 500GB drives. Should add about 3TB to my list. Unfortunately, I've only earned about 125 BURST since I started over a month ago. Can honestly say I earn a lot more just streaming videos for points to turn into e-Gift cards and PayPal. However, until I need the storage on those disks, I might as well mine too.
