i hope someone knows what i'm talking about
Discussion in 'General Gaming' started by CJL18, May 26, 2005.
  1. CJL18
    CJL18 [H]Lite
    94
    May 25, 2005
    but with san andrea's coming out i want to know where i can find a adpater where you can play with your ps2 controller on the computer. I remeber i saw my cousin paly vice city on the pc with his ps2 controller but i never knew where youc ould buy the adaper or what it was called, can someone tell me where i can find this ;)
  2. FunkStar
    FunkStar Gawd
    764
    Aug 7, 2004
    Try lik-sang.com
  3. michealo
    michealo [H]ard|Gawd
    1,285
    Jun 22, 2004
    a playstaion 2 to USB adaptor
    they're all over ebay
  4. CJL18
    CJL18 [H]Lite
    94
    May 25, 2005
    yep thats exactly what i was looking for ty for your help, i wonder if it will work for xbox to :p
  5. TheGamerZ
    TheGamerZ [H]ardness Supreme
    5,217
    Sep 18, 2003
    You can get them for every console. I have one for NES, SNES, and PSOne
  6. kpedge
    kpedge Gawd
    804
    Jul 7, 2004
    Sir, you are hardcore :p
  7. slowbiz
    slowbiz 2[H]4U
    2,455
    Aug 24, 2004
    Okay, I mentioned this in the other San Andreas thread.
    I have a PS2 to USB adapter. It ruined one of my PS2 controllers. It worked fine for quite some time, and then one day I went to use my PS2 controller, and it was totally fucked. It thought that most of the buttons were being held down, and the d pad didn't work at all. Someone at radio shack warned my brother about that happening when he was inquiring about an adapter for himself. I'm not sure if anyone knows exactly why it does this... but the radio shack person said that it's something electrically different between the pc and the ps2 that isn't good.
  8. ameoba
    ameoba [H]ardness Supreme
    6,413
    Jan 9, 2001
    The whole point of an adapter is to fix -exactly- these 'electrically differen[ces]" - if it's designed properly all the voltages and timings will be good.
    Beyond that, do you have anything other than a mild correlation to indicate that the adapter is at fault? Considering what it takes to work at Radio Shack, I'd trust what they say about as much as a wet fart.
  9. michealo
    1,285
    Jun 22, 2004
    was the adaptor bought at radio shack?
    if so, there's the problem
  10. Hate_Bot
    Hate_Bot 2[H]4U
    3,334
    Jan 23, 2005
    For the xbox, since it uses technical USB cables, a simple soldering job will get it to work on the computer
  11. Aaron_ATX
    Aaron_ATX [H]ard|Gawd
    1,801
    Oct 15, 2003
    Used a radio shack adapter for a long time on a PS2 controller and I have no problems.
  12. KidzMD
    KidzMD Limp Gawd
    400
    Sep 5, 2003
  13. slowbiz
    slowbiz 2[H]4U
    2,455
    Aug 24, 2004
    I didn't buy the adapter at Radioshack. The reason I asked about it was because I don't expect Radioshack employees to be [H]ardcore. I am pretty sure the adapter is what ruined my controller. I take excellent care of all my things. The controller is physically in mint condition, and it's 3 years old. It was plugged into my computer, and worked fine, and then the next day it was totally fucked. Any suggestions on how to troubleshoot/fix the damn thing?
  14. TheGamerZ
    5,217
    Sep 18, 2003
    Yea, these spiffy 30 button, ergonomic gamepads just don't cut it when you wanna go play some Megaman or the like. You've gotta have the pointy uncomfortable controller :p
  15. ameoba
    6,413
    Jan 9, 2001
    Unless you know about circuits & digital electronics and own a multimeter & a logic probe already, you're probably best off spending the $25 it'll cost to replace it. You might be able to take it apart and check for loose connections or dirty contacts on the buttons but, beyond that, they're not intended to be user servicable.
  16. shadowbreaker513
    shadowbreaker513 [H]ard|Gawd
    1,410
    Feb 15, 2005
    That's what I did, works great. There is one extra cable which I'm guessing is for the rumble. You just gotta get good drivers or else it sucks.
  17. heatsinker
    heatsinker [H]ardness Supreme
    5,470
    Feb 4, 2001
    The yellow cable (I think it was the yellow) is proprietary to the Xbox and is mainly for letting the Xbox know that a controller is connected.
  18. Matrox462
    Matrox462 Gawd
    926
    Feb 25, 2004
    me too! :p I got mine on clearance for $5
  19. Matrox462
    Matrox462 Gawd
    926
    Feb 25, 2004
    Don't forget the "if-all-else-fails-try-hitting-it-really-hard" technique ;)
  20. shadowbreaker513
    1,410
    Feb 15, 2005
    Hey, that worked on my modem for a long while until the cable plug snapped off the pcb inside.
  21. busta_cap
    busta_cap Limp Gawd
    282
    Aug 15, 2004
    It's surprising how often giving it a good whack works. "Percussive maintenance" is a valid technique, though it shouldn't be the first thing you try.
  22. kpedge
    kpedge Gawd
    804
    Jul 7, 2004
    Sometimes yelling and cursing works. Or hang it over the garbage can until it gets the idea.
  23. Matrox462
    Matrox462 Gawd
    926
    Feb 25, 2004
    Of course, and that's why it's called "If-all-else-fails..." meaning, a last resort ;)
