Just putting this out there for the record, because I couldn't find any solid info on this.
My TX750, like many others though not all, had a relatively noisy fan. Googling I came up with the following reports:
1. The stock yate loon has a very low starting voltage, so replacement fans may not work as they won't start spinning.
2. Unplugging the stock yate loon (and connecting the replacement fan to an exterior connection) will be sensed by the power supply and it won't allow boot.
I threw caution to the wind and bought an Antec 140mm truequiet.
1. After modifying the Antec's connector to plug into the power supply, I found that it indeed would not start to spin.
2. The power supply did actually allow boot without any fan plugged in.
Solution:
I routed the Antec fan's wires out of the power supply and connected it via molex. Works like a charm. Airflow is less than the stock yate loon, but the air coming out of the power supply is fairly cool. Oh and my PC is awesomely quiet now!
Solution:
