i have a question about 2 cpu
kevinf
i am thinking about getting the opteron 175, but i have also looked at the FX-55. should i get the FX-55 even though it is not dual core
DeChache
It really depends on what you are doing with your computer. Personally I would grab the Dual core. But in some cases clock speed will come out ahead.
kevinf
are there any benchmark tests on these 2 processors so i can easily compare
D
Deleted member 143938
Guest
Well looking at your current system specs, if you're only upgrading the CPU you're in for major bottblenecks left and right, first of all your value RAM, it'll be a true pain to try to overclock with that, second, your gfx card is very old, you'll get very low framerates not matter what. Third your CD ROM speeds are low, 16x??? wow... JK, but yeah don't waste money on that unless you're building a whole new system
kevinf
i am going to be upgrading the processor, and save some more money and upgrade the video card when dx10 comes out.
BTW, i am not overclocking
D
Guest
Probably the FX then
kevinf
but i also mutiltask a lot so i don't know whether or not a dual core processor will be a better deal or not
D
Guest
Depends on what kind of multitasking, if you're thinking the open one Firefox window and notepad in the other, you won't need this, it really only comes in handy when you like to virus scan during gaming or encode and the like a lot
