Basically, I reformatted this old as Sony for my parents to use (model PCV-RX750) and every time I try to increase the res to anything higher than the default (800x600) it just says "video mode not supported." I installed the SiS video drivers but I still couldn't get anything to work, and when I dxdiag/run it, it doesn't detect crap (can't detect the SiS integrated graphics, everything is just n/a for Display. Nor can the comp detect the monitor (just says default monitor, can't change any settings like hz or anything, it doesn't detect shit). Whats weird is that the SiS drivers don't show up in the program files, and every time I install them, it says they haven't been installed. What? And the res changing worked fine before I reformatted it.
I tried using two different monitors too (syncmaster 151v, flatron 1710s [on the flatron it says out of range 37.5 kHz / 87 hz, don't know what the means, but I assume thats the same as video mode not supported]) but to no avail, but the thing was, I couldn't find monitor drivers for BOTH does monitors. Do you think that will solve it? Or should I use a program like AsTray plus to force 1024x768 on it?
here's what I'm talking about:
Thanks.
Thanks.
