If I understand correctly, negative airflow is better than postive. If so, that would mean it's better to have more air exhausting than intake? So would a 120x38mm fit in the front of A05NB while 120x25 in the back?
Dying to replace my Antec case that I've used since 2006.
There's an upcoming sale for Lian Li PC-A05FNB @ Newegg Shellshocker today starting at 1pm PST.
http://www.newegg.com/Special/ShellShocker.aspx?cm_sp=ShellShocker-_-11-112-331-_-03022012_3
Don't know what the price will be but I guess ~70.
Kinda annoyed as I just ordered the A05NB 2 days ago.
Sign up for Shell Shocker previews and Newegg emails you the prices every morning at like 440am.How do you know how much it will cost?
Not enough room and I think that makes it look fugly anyways. I also, if I do that, then it would put more strain on the pump since i it will have to pump the water up.
I thought in a close loops, gravity was irrelevant (well 99%). This is due to the fact that when the loop is filled, the pump pushs water and 1 direction, while the negative force behind the pump pulls the water to neutralize itself.
Don't really like how I worded that, but I believe, but I believe the consent is right.
Well this is the second time I have this case- this one I bought used of wonSR4 and credit goes to him for the top blowholes- the rest I added
I love this case- compact, looks cool and cools really well.
Wiring is much better in person then it appears to be in the pictures.
I see those 2 top fans are set up as exhaust right?
I ask this because i'm going to use my gtx260 sc for my upcoming amd fx build (workstation) If i'm correct the gtx260 uses an intake fan to cool the card...
So does the 2 top exhaust fans and the intake fan from the gpu (correct me if i'm wrong)
have a conflict with each other? Meaning the air needed for the gpu is taken away by the 2 top fans. I could use the 2 top fans as intake but then again this means more dust build up...Are there people who have the top fans as exhaust please tell me your findings in temps...
Yes the two top fans are exhaust which is a must with this case and a high end system- you want the hot air exhausted as hot air rises- otherwise it gets trapped up top and causes high temps....
In that picture I was using an ATI 5850 which sucks air in and blows it out through the back of the card- never any issues with it...There is air coming in from the front of the case (120mm fan in hdd cage) so you should be fine.
Internal Radiator is for Lanparty only use, external connections are for a Mora 2 Pro
Specs :
i7-970 with Heatkiller 3.0
GTX 580 with GPU-X³ Nickel Hole Edition and EK Nickel Backplate
Rampage III Gene with Liquid Extasy Nickel Plexi Kühler for NB + Mosfet
Dominator GT 2000Cl8
WD Scorpio Blue 1T, WD Scorpio Black 500GB, Crucial M4 128GB (in 5.25" bay)
Phobya G-Changer 280
Noisblocker PK2
BitsPower Rad Grille
Laing Pro DDC-t with Alphacool top
EK Res X2 150 Advanced
Bitspower 10barbs ,Tygon, DP-Ultra red, Koolance VLN3
Aquacomputer Aquaero 4.0 LT, flowmeter and inline Temp Sensor.
Did some cutting :
Board with waterblocks :
First version of the loop without Res but T-Line (pita to bleed the air out)
Rebuild with Res X2
Actually I´ve added a distance piece between the "fangrille" outlet and the res to move the Pump off the rear wall of the case.
Plans... WEll maybe a AE5, New Psu (corsair Ax650) is allready at home and waiting for mdpcx parts
What tubing did you use, was it 3/8 5/8 Tygon Clear?
Update: Just got my HDD enclosures, this little box is stating to get heavy oh and I also got some brushed aluminum case feet!
Now if only I could decide what colors I want to sleeve my PSU in
What enclosures are these?
Hi guys. Is it possible, to use in this case, a 170mm PSU? Or it will be hard to mount motherboard?
