Well your paste could be settling in.
Bump vcore a notch, or the ioh core might need a bit too.... I think its the ioh core.
Target CPU Frequency 4200MHz
Target DRAM Frequency 1683MHz
LN2 Mode [Disabled]***
QPI Loadline Calibration [Enabled]***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [20]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
MPS and ACPI MADT ordering [Modern ordering]
Intel(R) Virtualiyation Tech [Enabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Intel(R) Turbo Mode Tech [Disabled]
Intel(R) C-STATE Tech [Enabled]
C State package limit setting [Enabled]
BCLK Frequency [210]
PCIE Frequency [102]
DRAM Frequency [DDR3-1683MHz]
UCLK Frequency [3365MHz]
QPI Link Data Rate [7572MT/s]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency [7]
RAS# to CAS# Delay [8]
RAS# PRE Time [7]
RAS# ACT Time [20]
RAS# to RAS# Delay [Auto]
REF Cycle Time [88]
WRITE Recovery Time [Auto]
READ to PRE Time [Auto]
FOUR ACT WIN Time [Auto]
Back-To-BackCAS# Delay [Auto]
Timing Mode [1N]
Round Trip Latency on CHA [Auto]
Round Trip Latency on CHB [Auto]
Round Trip Latency on CHC [Auto]
WRITE To READ Delay(DD) [Auto]
WRITE To READ Delay(DR) [Auto]
WRITE To READ Delay(SR) [Auto]
READ To WRITE Delay(DD) [Auto]
READ To WRITE Delay(DR) [Auto]
READ To WRITE Delay(SR) [Auto]
READ To READ Delay(DD) [Auto]
READ To READ Delay(DR) [Auto]
READ To READ Delay(SR) [Auto]
WRITE To WRITE Delay(DD) [Auto]
WRITE To WRITE Delay(DR) [Auto]
WRITE To WRITE Delay(SR) [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full Calibration]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [1000KHz]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage [1.38125]
CPU PLL Voltage [Auto]
QPI/DRAM Core Voltage [1.48750]
DRAM Bus Voltage [1.65625]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage [1.20525]
IOH PCIE Voltage [Auto]
ICH Voltage [Auto]
ICH PCIE Voltage [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
***on-board jumper dependant
Don't forget to use the all button on linx. it makes the loops a lot longer and stresses all of your memory.
The all button never works for me, just spits out an error about running out and cancels. I use the preset closest to how much I have, works well enough. 9G free = 8GB problem set. I still get errors, and my core temps are starting to push to 80 in LinX :\. Bear in mind I'm not looking for 4 GHZ I'm happy gunning down 3.2 or 3.6. My case doesn't have the cooling for 4 as it is.
If you have 12gb ram and can only run 9gb on the test, you're not doing a thorough test. You need to free up the extra memory. Otherwise the consumed parts won't be stressed. If the 'slowest' part of your memory happens to be in that last 3gb, it will never get tested and you'll get random crashes later on during normal use.
Remember, 'safe' vQPI is up to 1.45v according to intel's spec for 45nm cpus. You WILL need a LOT of QPI to run your memory correctly. More than 1.4875v for sure since you're 6x2gb sticks instead of 3x4gb.
69C CPU temp sounds good to me with linpack (same as IBT?); RealTemp temperatures?Goddamn .. my temps are already getting too high too. 69C surface temp during linpack. I'm not sure 1.4xx is even an option, I'm at 1.35 right now.
Sell your RAM and go with 3×4GB if you want 12GBs. I'm at 1.35V on QPI with 3×2GB.
You can do it, BRO.
I run 6x2GB at stock speeds (1600) with a QPI of 1.3v. Maybe you need more for overclocking the RAM, but I have a completely stable setup with only 1.3v. I think the OP needs to put his vcore up as people have been telling him since page 1 of this thread.
I figured the 6sticks were gonna be a source of issue. I've never dealt with that much ram..
Yup. Remember mem controller on die with Bloomfield. Try running 6GB, reducing stress on mem controller. One of my 920s didn't like 6 sticks, had to go with 3x4GB.
