If you have a system dual booting on one drive and a second drive for storage and you can't write to the storage drive all of the sudden, but you can read from it, try this
sudo umount /dev/mapper/veracrypt4
sudo mount -t ntfs -o umask=000 /dev/mapper/veracrypt4 /media/veracrypt4
If you get the error
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Falling back to read-only mount because the NTFS partition is in an
unsafe state. Please resume and shutdown Windows fully (no hibernation
or fast restarting.)
Just go completely turn off hibernation in Win 10, there should be no hidden or protected hiberfile.sys in the C: drive at all.
