crazycrave
- Mar 31, 2016
I down sized my case as Newegg had a sale of $59 shipped for mATX RAIJINTEK STYX and Best Buy had the Corsair CX650M on sale for $59 to add to the build for power and heat sink is Deep Blue GAMMAXX 300R ..
case https://www.newegg.com/Product/Product.aspx?Item=9SIA66Z38G2791
Mother Board is MSI Gaming Pro 350B with Ryzen 5 1600 with G SKill Rip Jaw V Black 3200Mhz kit and drives are 256Mb INWIN SSD and 1TB Seagate Barracuda
Video card is Power Color Red Dragon RX 580 8Gb with driver 19.2.1 and using Watt Man I made a fan profile to tame those fans … MSI Command Center runs the cpu and case fans as to ramp as needed and has a cooler button to hit if you need the workload .
I only have 2 case fans as one upper intake and rear lower provided by Raijntek and Deep Blue pointing at rear fan . power supply = not running dvd drive I turn power supply fan that side as maybe half inch gap and every thing is up and running as it was a rip out and rebuild it as not having a dvd drive on a working system that had one before it did not like that shit .
So far I love this case as it's real Aluminum panel's and well built as I had plans to add 240mm cpu cooler but I am very pleased with air cooling it has provided those far in 72F room as temps look nice while in gaming load as I will upload a video with temps if anyone is interested in these type cases as the build was $700 and worth every penny.
It is in stock form as I am testing memory speeds as this is 3200Mhz http://www.3dmark.com/fs/18359211 in that case as Radeon Chill and Enhanced Sync with frame cap of 75fps help with keeping the RX 580 kind of your ears .
